Home » Modeling » Epsilon » How to validate only part of model(How to validate only part of model)
How to validate only part of model [message #1842761] Wed, 30 June 2021 12:55 Go to next message
Hello
I need to validate only part of model.
Is it possible to pass list of root objects. In this case only parent object and references will be validated?
Arseniy Isakov
Re: How to validate only part of model [message #1842771 is a reply to message #1842761] Wed, 30 June 2021 23:56 Go to previous messageGo to next message
Hi Arseniy,
Do you run your EVL constraints using the Java API, through an Eclipse run configuration, the EVL/EMF validation extension point [1], or the EVL ANT task?
Best,
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/evl-emf-integration/
[Updated on: Wed, 30 June 2021 23:56] by Moderator
Re: How to validate only part of model [message #1842848 is a reply to message #1842771] Fri, 02 July 2021 11:54 Go to previous messageGo to next message
Hi Dimitris
I am running EVL engine from my code.
I embedded it in my product building process.
So I am using java API outside of eclipse
Arseniy Isakov
[Updated on: Fri, 02 July 2021 19:37] by Moderator
Re: How to validate only part of model [message #1842857 is a reply to message #1842848] Sat, 03 July 2021 04:33 Go to previous messageGo to next message
Hi Arseniy,
You will need to subclass EvlModule to achieve this. I've shared an example showing how to do this in https://git.eclipse.org/c/epsilon/org.eclipse.epsilon.git/plain/examples/org.eclipse.epsilon.examples.standalone/src/org/eclipse/epsilon/examples/standalone/evl/SelectiveEvlModule.java
Best,
Dimitris
Re: How to validate only part of model [message #1842930 is a reply to message #1842857] Tue, 06 July 2021 16:49 Go to previous messageGo to next message
Thanks Dimitris
It is work fine.
Another question is it possible to add global variables to EVL module using java API
Arseniy Isakov
Re: How to validate only part of model [message #1842935 is a reply to message #1842930] Wed, 07 July 2021 01:42 Go to previous messageGo to next message
Hi Aresniy,
That's good to hear! I've added an example showing how to pass global variables to Epsilon programs in [1].
Best,
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/run-epsilon-from-java/#adding-variables
Re: How to validate only part of model [message #1842953 is a reply to message #1842935] Wed, 07 July 2021 11:43 Go to previous messageGo to next message
Hi Dimitris
		if (moduleElement instanceof ConstraintContext) {
		return new SelectiveConstraintContext();
This condition never become true. So SelectiveConstraintContext object never return back. Is it connected with version. I am on 1.4
my evl file looks like this
 import "tura:/generation-templates/template/commons/typeElementUtil.eol";
 context type::Type {
   constraint Type{
      check : self.getAllRecipeMappers()
      message : 'Runtime constraint ' + self.name+" -->"
operation type::Type getAllRecipeMappers() : Boolean {
    var type = self;
    if ( component.isKindOf(recipe::JavaScriptComponent)){
        return false;
    if ( component.isKindOf(recipe::JavaComponent)){
          if ( ingredient.controllerLayer == null){
             type.mappingType2Java(recipe,ingredient,'MODEL');
             if (type.~mapper <> null  and  not type.~mapper.equals("NA") and  ( type.isKindOf(type::Primitive) or  ( not type.isKindOf(type::Primitive) and  type.~library <> null ) )){
                     type.mappingType2Java(recipe,ingredient,'VIEW');
                         return true;
                return false;
             return false;
          }else{
             type.mappingType2Java(recipe,ingredient);
                  return true;
             return false;
    return false;
Re: How to validate only part of model [message #1842959 is a reply to message #1842953] Wed, 07 July 2021 15:30 Go to previous messageGo to next message
Actually it is not working for 2.3.2
Re: How to validate only part of model [message #1842962 is a reply to message #1842959] Wed, 07 July 2021 21:15 Go to previous messageGo to next message
Hi Dimitris
I found an issue
I have 2 files
first is mainTypeMappingValidationRules.evl
import "tura:/generation-templates/validation/rules/runtimeTypedefinitionValidationRules.evl";
second file runtimeTypedefinitionValidationRules.evl
   constraint Type{
    var type = self;
        return false;
                         return true;
                return false;
             return false;
          }else{
                  return true;
             return false;
    return false;
if I parse with SelectiveEvlModule first file
code below never fires
Re: How to validate only part of model [message #1842966 is a reply to message #1842962] Thu, 08 July 2021 03:50 Go to previous messageGo to next message
Hi Arseniy,
Could you please put together a minimal example [1] that I can use to reproduce the issue you're encountering and investigate?
Best,
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: How to validate only part of model [message #1842971 is a reply to message #1842966] Thu, 08 July 2021 06:38 Go to previous messageGo to next message
Hi Dimitris
See an archive.
Arseniy Isakov
Re: How to validate only part of model [message #1842975 is a reply to message #1842971] Thu, 08 July 2021 07:20 Go to previous messageGo to next message
So your final example has to look like this
package org.eclipse.epsilon.examples.standalone.evl;
import java.io.File;
import java.util.Arrays;
import java.util.Collection;
import java.util.HashMap;
import java.util.List;
import java.util.stream.Collectors;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.epsilon.common.module.ModuleElement;
import org.eclipse.epsilon.common.parse.AST;
import org.eclipse.epsilon.common.parse.problem.ParseProblem;
import org.eclipse.epsilon.emc.emf.InMemoryEmfModel;
import org.eclipse.epsilon.eol.exceptions.models.EolModelElementTypeNotFoundException;
import org.eclipse.epsilon.eol.exceptions.models.EolModelNotFoundException;
import org.eclipse.epsilon.evl.EvlModule;
import org.eclipse.epsilon.evl.dom.ConstraintContext;
import org.eclipse.epsilon.evl.execute.context.IEvlContext;
 * Demonstrates subclassing EvlModule to only check constraints against a
 * selection of model elements
public class SelectiveEvlModule extends EvlModule {
protected static List<EObject> rootEObjects;
	public ModuleElement adapt(AST cst, ModuleElement parentAst) {
		ModuleElement moduleElement = super.adapt(cst, parentAst);
		return moduleElement;
	public HashMap<String, Class<?>> getImportConfiguration() {
		HashMap<String, Class<?>> importConfiguration = super.getImportConfiguration();
		importConfiguration.put("evl", SelectiveEvlModule.class);
		return importConfiguration;
	class SelectiveConstraintContext extends ConstraintContext {
		public Collection<?> getAllOfSourceKind(IEvlContext context)
				throws EolModelElementTypeNotFoundException, EolModelNotFoundException {
			// Only return a subset containing elements which are
			// descendants of one of the root objects
			return super.getAllOfSourceKind(context).stream().filter(e -> shouldCheck(e)).collect(Collectors.toList());
	protected boolean shouldCheck(Object object) {
		// Only check elements which are decendants of one of the
		// root objects
		return EcoreUtil.isAncestor(rootEObjects, (EObject) object);
	public void setRootEObjects(List<EObject> rootEObjects) {
		this.rootEObjects = rootEObjects;
	public List<EObject> getRootEObjects() {
		return rootEObjects;
	public static void main(String[] args) throws Exception {
		SelectiveEvlModule module = new SelectiveEvlModule();
		ResourceSetImpl resourceSet = new ResourceSetImpl();
		resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
		Resource resource = resourceSet.createResource(URI.createURI("foo.ecore"));
		resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
		// Create 2 classes C1 and C2 with one attribute each
		EClass c1 = EcoreFactory.eINSTANCE.createEClass();
		c1.setName("C1");
		EAttribute a1 = EcoreFactory.eINSTANCE.createEAttribute();
		a1.setName("a1");
		c1.getEStructuralFeatures().add(a1);
		EClass c2 = EcoreFactory.eINSTANCE.createEClass();
		c2.setName("C2");
		EAttribute a2 = EcoreFactory.eINSTANCE.createEAttribute();
		a2.setName("a2");
		c2.getEStructuralFeatures().add(a2);
		resource.getContents().add(c1);
		resource.getContents().add(c2);
		InMemoryEmfModel model = new InMemoryEmfModel(resource);
		// Constraint for EAttibute
		module.parse(new File("mainRules.evl"));
		if (module.getParseProblems().size() > 0) {
			for (ParseProblem problem : module.getParseProblems()) {
				System.out.println(problem.toString());
			return;
		module.getContext().getModelRepository().addModel(model);
		// Only elements under C1 (i.e. attribute a1) should be checked
		module.setRootEObjects(Arrays.asList(c1));
		module.execute();
Re: How to validate only part of model [message #1842976 is a reply to message #1842975] Thu, 08 July 2021 07:25 Go to previous message
Indeed - I was just about to reply with the same solution but you beat me to it :)
Best,
Dimitris
Previous Topic:Multiple object type assignment to one object type
Next Topic:Element shown twice in target metamodel
Current Time: Sun Nov 02 05:13:20 EST 2025
Powered by FUDForum. Page generated in 0.05006 seconds
