Eclipse starts with blank window on Mac [message #1842751] |
Wed, 30 June 2021 13:38 |
Frä Fröhlich Messages: 22 Registered: June 2021 |
I installed Eclipse 2018(https://www.eclipse.org/downloads/packages/release/2018-09/r/eclipse-ide-java-and-dsl-developers). I need this specific version and had it running on my old Mac already (new Mac has fresh installation).
I use Java 8 (openjdk version "1.8.0_292"
OpenJDK Runtime Environment (AdoptOpenJDK)(build 1.8.0_292-b10)
OpenJDK 64-Bit Server VM (AdoptOpenJDK)(build 25.292-b10, mixed mode))
1st I can't start it from double clicking, but have to use cli for it(can't find java home). I have seen some posts on how to fix this, so this is not my issue.
2nd: When I open Eclipse I get a blank page (see appendix).
I am unable to do anything. When I click on menu items (e.g. preferences) nothing happens.
I also started eclipse from cli and didn't see anything specific in the execution logs.
[Updated on: Wed, 30 June 2021 14:03] Report message to a moderator
Re: Eclipse starts with blank window on Mac [message #1842788 is a reply to message #1842785] |
Thu, 01 July 2021 11:36 |
Ed Merks Messages: 33139 Registered: July 2009 |
Perhaps you're assuming that your project dependencies must be satisfied by what's in your installation. You can use a newer version of Eclipse and populate the target platform with older versions of the dependencies.
I really don't know what to say about the fact you can't get it to work on your new mac where you had it working before.... What changed since you had it running?
Ed Merks
FUDForum. Page generated in 0.08422 seconds
