Home » Modeling » EMF » [EMF] parse enum values surrounded by whitespace
[EMF] parse enum values surrounded by whitespace [message #1842705] Tue, 29 June 2021 12:13 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I created a genmodel (and ecore model) from an existing xml schema definition. The model contains a couple of enumerations. Then I generate an implementation and try to read some of the models I have (using the xmi serialization). These models are manually created. When parsing a list of enumeration values, some users have written:
   <SupportedFormats>
      <elt>SUPPORTED_REPORT_FORMAT_TYPE_XML</elt>
   </SupportedFormats>
Others have written:
   <SupportedFormats>
      <elt>
      </elt>
   </SupportedFormats>
The implementation I generated, does not succesfully parse the second example as it tries to lookup an enumeration value that includes the newlines after <elt> and before </elt>.
Is there a way to configure the xmi parser such that it 'trims' whitespace of enumeration before trying to match them agains the set of allowed values?
Wilbert
Re: [EMF] parse enum values surrounded by whitespace [message #1842709 is a reply to message #1842705] Tue, 29 June 2021 12:44 Go to previous messageGo to next message
You'll need to specialize the implementation of the generated XyzFactoryImpl.createAbcFromString method to trim whitespace before looking up the enumerator.
Ed Merks
Re: [EMF] parse enum values surrounded by whitespace [message #1842711 is a reply to message #1842709] Tue, 29 June 2021 12:50 Go to previous message
Hi Ed,
You just beat me to it.
The genmodel properties for an enumeration containa 'Convert-to-string Body' and a 'Create-from-string Body'. Copying the generated code of another enumeration and inserting the trim() operation in the Create-from-string Body did the trick indeed.
Thanks!
Wilbert.
Previous Topic:Parsing a nested JSON containment references list
Next Topic:EMF model in runtime
Current Time: Thu Sep 21 20:24:08 GMT 2023
Powered by FUDForum. Page generated in 0.02072 seconds
