Home » Language IDEs » C / C++ IDE (CDT) » Incremental build not working correctly
Incremental build not working correctly [message #1842516] Tue, 22 June 2021 05:49 Go to next message
Nissan Aloni is currently offline Nissan AloniFriend
I've been advised to duplicate my topic into this forum.
The original thread can be found here: https://www.eclipse.org/forums/index.php?t=msg&th=1108294&goto=1842478&#msg_1842478
I will also copy paste my messages with all the information below this one.
THanks.
Re: Incremental build not working correctly [message #1842517 is a reply to message #1842516] Tue, 22 June 2021 05:50 Go to previous messageGo to next message
I am working with an Eclipse based IDE.
My workspace is composed of 3 projects:
1. BSP
2. A SW library
3. A system project that uses the BSP and library and builds the final target
I noticed that the incremental build has strange behavior.
On first clean - it build all the sources.
On following build nothing is built - as expected.
On a consecutive build - all the files in the 3rd project are built again.
Then nothing is built and then again everything is rebuilt.
How can I debug it?
How can I tell what is causing this behavior - is it a problematic configuration? Is it something that the IDE supplier changed in Eclipse? Is it a bug in Eclipse?
Which log files should I include/investigate to understand the root cause?
Cheers.
Re: Incremental build not working correctly [message #1842518 is a reply to message #1842517] Tue, 22 June 2021 05:50 Go to previous messageGo to next message
I am building C based projects.
I have tried contacting the vendor that supplied the IDE - but so far didn't get any response or support. I was hoping the good and professional folks of this community might more knowledgeable and can direct on where to look for and maybe what to look for.
I saw the following log files are created:
myproj_Debug.build.ui.log
But I didn't see any clue to why the incremental build triggered a full build.
There is also IDE.log file in the workspace. I didn't see anything useful there as well.
Here's the content of .\.metadata\.plugins\org.eclipse.cdt.ui\global-build.log
Nothing to build in platform 'trenz_wrapper'
17:36:11 **** Incremental Build of configuration Debug for project sw_c ****
make -j8 all
make: Nothing to be done for 'all'.
17:36:14 **** Incremental Build of configuration Debug for project myproj ****
make all
17:36:15 **** Incremental Build of configuration Debug for project myproj_system ****
make -j8 all
but on a consecutive build
17:38:12 **** Incremental Build of configuration Debug for project sw_c ****
make -j8 all
17:38:15 **** Clean-only build of configuration Debug for project myproj****
make clean
Thanks.
Re: Incremental build not working correctly [message #1842520 is a reply to message #1842518] Tue, 22 June 2021 06:57 Go to previous message
David VavraFriend
This will be hard to debug.
Assuming it's a Make problem
Part of the problem might be the -j8 option which may be causing a race condition.
You can get a print out of what make thinks is going on with the --debug=v option
includes messages about which makefiles were parsed, prerequisites that did not need to be rebuilt, etc.
For more info:
https://www.gnu.org/software/make/manual/html_node/Options-Summary.html
You might want to get a string of your own debug messages
using the $(info text...) macro
From the Make manual:
https://www.gnu.org/software/make/manual/html_node/Make-Control-Functions.html
Will be very hard to follow when using a parallel build.
All of the above assumes GNU Make.
Possible CDT error
CDT might be causing this behavior.
If so, submit a bug report.
But don't expect much if using a third party plugin.
You should try to debug as much of this as you can before doing so.
Try to form a minimum case that exhibits the problem.
Don't expect any quick fixes but you may get a workaround.
[Updated on: Tue, 22 June 2021 06:58]
Report message to a moderator
Previous Topic:how to import vc++ project in Eclipse IDE
Next Topic:GCOV plugin error in latest update for plugin version 8.3.0
Current Time: Tue Aug 09 02:47:12 GMT 2022
Powered by FUDForum. Page generated in 0.02213 seconds
