Is there a way to use the Object Inserter and have it show up in the File system [message #1842450] |
Sun, 20 June 2021 00:08 |
Heavens Regent Messages: 7 Registered: May 2021 |
Update: Turns out the issue was somewhere else, I assumed since I wasn't seeing the files in the git repository it was sticking them somewhere random. However, is the main question is still valid. Is there a way to make the files show up in the file system while using ObjectInserter (as seen below)
Is there some way to use the ObjectInserter and save the files to a certain directory on the filesystem? When I've used ObjectInserter (see code below) I can't get it to save to a certain directory.
I don't care if I can see the actual files on the file system, but I need the files to be saved to a specific directory. I've only been able to do that with the second set of code. The first set of code runs much faster especially the retrieve file object part.
This code is working really fast but I can't find the generated files on the file system
Save Object w/ObjectInserter
ObjectInserter objectInserter = repository.newObjectInserter();
ObjectId blobId = objectInserter.insert(Constants.OBJ_BLOB, fileContents.getBytes());
objectInserter.flush();
TreeFormatter treeFormatter = new TreeFormatter();
treeFormatter.append(fileName, FileMode.REGULAR_FILE, blobId);
ObjectId treeId = objectInserter.insert(treeFormatter);
TreeWalk treeWalk = new TreeWalk(repository);
treeWalk.addTree(treeId);
treeWalk.next();
Retrieve object w/ObjectReader
ObjectReader objectReader = git.getRepository().newObjectReader();
ObjectLoader objectLoader = objectReader.open(blobId);
return new String(objectLoader.getBytes());
This code is a lot slower, but I am able to find the files on the file system
Save Object w/Java FileWriter
File myFile = new File(repository.getDirectory().getParent(), fileName);
FileWriter myWriter = new FileWriter(filePath);
myWriter.write(fileContents);
myWriter.close();
myFile.createNewFile();
Read object with Scanner
File myObj = new File("/jgit/" + repoName + "/" + fileName);
Scanner fileReader = new Scanner(myObj);
String fileData = "";
while (fileReader.hasNextLine()) {
fileData += fileReader.nextLine();
[Updated on: Sun, 20 June 2021 00:26] Report message to a moderator
Re: Is there a way to use the Object Inserter and have it show up in the File system [message #1842737 is a reply to message #1842467] |
Wed, 30 June 2021 08:42 |
Somehow I'm losing access to the objects I am inserting with ObjectInserter. I'm storing the blobId returned from objectInserter.insert(...) in the database.
It seems like I'm either doing something that removes the objects from the .git/objects/ or somehow I'm not saving the objects to the repository.
Are there any basic git commands that would overwrite the stuff there? For example:
git.add().addFilepattern(fileName).call();
On the other side, this is how I retrieve the git repository. Is there something about the way I'm doing this that doesn't actually reference this repository?
The reason this is important is that directory is the only safe directory on the system
Git git = Git.open(new File("/jgit/repoName/"))
Repository repository = git.getRepository();
[Updated on: Wed, 30 June 2021 08:54] Report message to a moderator
Re: Is there a way to use the Object Inserter and have it show up in the File system [message #1842741 is a reply to message #1842740] |
Wed, 30 June 2021 09:37 |
If I retrieve a file, make updates to the file, then save that file, does that mean that file v2 has no correlation to file v1? also meaning the blobId will be different?
Edit:
Also doesn't the below code do what you are saying I need to do?
I apologize if I seem dense, I've read through that page about many times over the course of the last 2 months and I'm just barely beginning to understand the git plumbing commands and how that relates to what I'm doing in JGit
treeWalk.next();
[Updated on: Wed, 30 June 2021 09:51] Report message to a moderator
Re: Is there a way to use the Object Inserter and have it show up in the File system [message #1842750 is a reply to message #1842741] |
Wed, 30 June 2021 13:16 |
Christian Halstrick Messages: 274 Registered: July 2009 |
That's true: If you version a file 'f.txt' containing the content 'test content' then the text 'test content' will be stored in a blob with name .git/objects/d6/70460b4b4aece5915caf5c68d12f560a9fe3e4. When you then modify the file f.txt and change the content to 'hello world' and add and commit that, then there will be a new blob persisted in .git/objects/3b/18e512dba79e4c8300dd08aeb37f8e728b8dad containing content 'hello world'. And from the blobs you can't detect that they both belong to 'f.txt' and one is the successor content of the same versioned file. If you afterwards add and commit a new file 'g.txt' with the content 'hello world' then ... no new blobs will be written to the object database. We will have a new tree object saying that the root folder has now two entries (f.txt, g.txt) and that both files have content stored in .git/objects/3b/18e512dba79e4c8300dd08aeb37f8e728b8dad. Two completely different files with different pathes do share the same content and therefore there is only one blob persisted. It's the tree object which finally maps filenames to blob objects.
Regarding whether your code is correct: No, you care about creating trees and blobs ... but both are not yet referenced by any ref (commit, tag). Means, after your code is executed and you wait long enough then git may run a garbage collection and will find out that neither the tree nor the blobs are reachable by any ref. Therefore they are garbage and can be deleted. You need to create a commit referencing you tree (and by that the blob) and additionally you need a ref which points to your commit. Otherwise the commit is also garbage and therfore tree and blob also.
I would suggest you start with a working tree based version of your code which uses high level commands like add, commit, checkout and inspect how the object database changes. Then, if this works, start optimizing by getting rid of the need to write content to the working tree.
Ciao
Chris
FUDForum. Page generated in 0.03300 seconds
