Re: xtext 2.25.0 + jdk 11.0.11 [message #1842321 is a reply to message #1842320] |
Wed, 16 June 2021 12:59 |
z232 I Messages: 48 Registered: February 2016 |
Member |
The newWorkspace and the eclipse folder are placed on Desktop
I get the same error.
[main] INFO org.eclipse.jetty.util.log - Logging initialized @229ms to org.eclipse.jetty.util.log.Slf4jLog
[main] INFO org.eclipse.jetty.server.Server - jetty-9.4.34.v20201102; built: 2020-11-02T14:15:39.302Z; git: e46af88704a893fc12cb0e3bf46e2c7b48a009e7; jvm 11.0.11+9-LTS-194
[main] WARN org.eclipse.jetty.webapp.WebAppContext - Failed startup of context o.e.j.w.WebAppContext@130d63be{/,file:///C:/Users/PowerLab/Desktop/newWorkspaceEclipse/org.xtext.example.mydsl.parent/org.xtext.example.mydsl.web/WebRoot/,STOPPED}
java.nio.file.NoSuchFileException: C:\org.xtext.example.mydsl.web\bin\default
at java.base/sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:85)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:103)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:108)
at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.readAttributes(WindowsFileAttributeViews.java:53)
at java.base/sun.nio.fs.WindowsFileAttributeViews$Basic.readAttributes(WindowsFileAttributeViews.java:38)
at java.base/sun.nio.fs.WindowsFileSystemProvider.readAttributes(WindowsFileSystemProvider.java:198)
at java.base/java.nio.file.Files.readAttributes(Files.java:1764)
at java.base/java.util.zip.ZipFile$Source.get(ZipFile.java:1231)
at java.base/java.util.zip.ZipFile$CleanableResource.<init>(ZipFile.java:732)
at java.base/java.util.zip.ZipFile$CleanableResource$FinalizableResource.<init>(ZipFile.java:848)
at java.base/java.util.zip.ZipFile$CleanableResource.get(ZipFile.java:837)
at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:247)
at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:177)
at java.base/java.util.jar.JarFile.<init>(JarFile.java:348)
at java.base/sun.net.www.protocol.jar.URLJarFile.<init>(URLJarFile.java:103)
at java.base/sun.net.www.protocol.jar.URLJarFile.getJarFile(URLJarFile.java:72)
at java.base/sun.net.www.protocol.jar.JarFileFactory.get(JarFileFactory.java:176)
at java.base/sun.net.www.protocol.jar.JarURLConnection.connect(JarURLConnection.java:131)
at java.base/sun.net.www.protocol.jar.JarURLConnection.getJarFile(JarURLConnection.java:92)
at org.eclipse.jetty.webapp.MetaInfConfiguration.getTlds(MetaInfConfiguration.java:445)
at org.eclipse.jetty.webapp.MetaInfConfiguration.scanForTlds(MetaInfConfiguration.java:361)
at org.eclipse.jetty.webapp.MetaInfConfiguration.scanJars(MetaInfConfiguration.java:172)
at org.eclipse.jetty.webapp.MetaInfConfiguration.preConfigure(MetaInfConfiguration.java:101)
at org.eclipse.jetty.webapp.WebAppContext.preConfigure(WebAppContext.java:488)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:523)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
at org.eclipse.jetty.server.Server.start(Server.java:423)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:97)
at org.eclipse.jetty.server.Server.doStart(Server.java:387)
at org.xtext.example.mydsl.web.ServerLauncher.main(ServerLauncher.java:39)
[main] INFO org.eclipse.jetty.server.AbstractConnector - Started ServerConnector@5204062d{HTTP/1.1, (http/1.1)}{localhost:8080}
[main] INFO org.eclipse.jetty.server.Server - Started @599ms
[main] INFO org.xtext.example.mydsl.web.ServerLauncher - Server started http://localhost:8080/...
[Thread-8] INFO org.xtext.example.mydsl.web.ServerLauncher - Press enter to stop the server...
Out of thoughts.
[Updated on: Wed, 16 June 2021 13:00] Report message to a moderator
FUDForum. Page generated in 0.03609 seconds
