Re: still trying to get started [message #1842032 is a reply to message #1841941] |
Mon, 07 June 2021 22:34   |
Paul Kagan wrote on Thu, 03 June 2021 22:00it doesn't look similar or "sound" similar in any way. there is no face-config.xml file in my project that needs fixing...
I guess the similarity is that we are all having a problem it looks similar to something else is a great way to throw me down a tunnel and bury my issue...
There's one mentioned in your sometimes-happening error message, which is why I directed you to the Lemminx Issue.
As for the Facet problem, I already talked about it in the other thread at https://www.eclipse.org/forums/index.php?t=msg&th=1108030&goto=1841764&#msg_1841764. You can fix it by changing the values on the the Project Facets or Java Compiler property page, or possibly by making sure there's a Java 16 JDK set on your Installed JREs preference page.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Fri, 25 June 2021 21:35] Report message to a moderator
Re: still trying to get started [message #1842633 is a reply to message #1842624] |
Fri, 25 June 2021 21:34  |
Mumtahina, that should probably have been a separate thread, but you can not directly serve anything under WEB-INF to clients like a web browser. That's where you put private resources and class files--which you definitely don't want someone decompiling for secrets.
Nitin Dahyabhai
[Updated on: Fri, 25 June 2021 21:37] Report message to a moderator
FUDForum. Page generated in 0.04046 seconds
