Home » Newcomers » Newcomers » Error after launch workspace
Error after launch workspace [message #1841908] Wed, 02 June 2021 18:44 Go to next message
Moritz Martin is currently offline Moritz MartinFriend
I installed eclipse and every time starting any workspace i get this error message in log files.
!SESSION 2021-06-02 20:26:48.665 -----------------------------------------------
eclipse.buildId=4.19.0.I20210303-1800
java.version=15.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.jface 2 0 2021-06-02 20:27:19.248
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2021-06-02 20:27:19.248
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@31e22365,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2ebf524,
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2021-06-02 20:27:43.698
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4915)
at org.eclipse.swt.SWT.error(SWT.java:4804)
at org.eclipse.swt.SWT.error(SWT.java:4775)
at org.eclipse.swt.widgets.Widget.error(Widget.java:438)
at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:76)
at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:68)
at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2567)
at org.eclipse.ui.internal.StandardTrim.createProgressBar(StandardTrim.java:76)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:52)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:346)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:227)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:94)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:37)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:999)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:765)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:730)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:714)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:109)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:673)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:688)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1083)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-06-02 20:27:43.719
!MESSAGE
!STACK 0
java.lang.NullPointerException: Cannot invoke "org.eclipse.swt.widgets.Shell.layout()" because the return value of "org.eclipse.ui.internal.WorkbenchWindow.getShell()" is null
at org.eclipse.ui.internal.ViewIntroAdapterPart.setBarVisibility(ViewIntroAdapterPart.java:231)
at org.eclipse.ui.internal.ViewIntroAdapterPart.dispose(ViewIntroAdapterPart.java:151)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:264)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:421)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:456)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:160)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:83)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:105)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:68)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:186)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:171)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499)
at org.eclipse.osgi.container.Module.doStop(Module.java:658)
at org.eclipse.osgi.container.Module.stop(Module.java:521)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:221)
at java.base/java.lang.Thread.run(Thread.java:832)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-06-02 20:27:43.725
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.SWT.error(SWT.java:4889)
at org.eclipse.swt.widgets.Display.error(Display.java:1262)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:779)
at org.eclipse.ui.internal.WorkbenchWindow$3.changed(WorkbenchWindow.java:886)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:108)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:364)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:188)
!ENTRY org.eclipse.osgi 4 0 2021-06-02 20:28:11.390
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2021-06-02 20:28:11.394
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:816)
at org.eclipse.swt.widgets.Display.getData(Display.java:1745)
at org.eclipse.ui.internal.WorkbenchPlugin.getSplashShell(WorkbenchPlugin.java:1192)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getDefaultParent(ProgressManagerUtil.java:489)
at org.eclipse.ui.internal.statushandlers.InternalDialog.<init>(InternalDialog.java:152)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:246)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:188)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:152)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:79)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.lambda$0(WorkbenchErrorHandler.java:54)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4001)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:3363)
!SESSION 2021-06-02 20:33:37.456 -----------------------------------------------
java.version=15.0.2
!ENTRY org.eclipse.jface 2 0 2021-06-02 20:33:43.156
!SUBENTRY 1 org.eclipse.jface 2 0 2021-06-02 20:33:43.156
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@362be0cd,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2dde0a34,
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2021-06-02 20:33:47.537
!STACK 1
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-06-02 20:33:47.555
!MESSAGE
!STACK 0
java.lang.NullPointerException: Cannot invoke "org.eclipse.swt.widgets.Display.disposeExec(java.lang.Runnable)" because "toQuery" is null
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:214)
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:232)
at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:105)
at org.eclipse.ui.internal.views.markers.ExtendedMarkersView.dispose(ExtendedMarkersView.java:619)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2021-06-02 20:33:47.567
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2021-06-02 20:33:49.834
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2021-06-02 20:33:49.838
!STACK 0
Re: Error after launch workspace [message #1841911 is a reply to message #1841908] Wed, 02 June 2021 20:25 Go to previous message
Thomas Wolf is currently offline Thomas WolfFriend
That looks very much like a recurrence of bug 552980. That one should have been fixed in the Eclipse 4.19 you're using, though.
Please file a new bug report.
Previous Topic:Build errors
Next Topic:Errors starting out
Current Time: Thu Jul 07 08:50:16 GMT 2022
Powered by FUDForum. Page generated in 0.03372 seconds
