Home » Eclipse Projects » Eclipse JustJ » Working configuration to build products, plug-ins and features together
Working configuration to build products, plug-ins and features together [message #1841086] Mon, 03 May 2021 08:51 Go to next message
The documentation of JustJ says that products that use a JustJ JRE feature cannot build together with features and plug-ins using Maven/Tycho.
Therefore I want to report that since Tycho 2.3.0 the following configuration in the pom.xml works perfectly fine in the mentioned scenario:
<plugin>
    <groupId>org.eclipse.tycho</groupId>
    <artifactId>target-platform-configuration</artifactId>
    <version>${tycho-version}</version>
    <configuration>
        <executionEnvironment>org.eclipse.justj.openjdk.hotspot.jre.full-11</executionEnvironment>
    </configuration>
</plugin>
Note that it is important to specify the executionEnvironment.
Specifying the executionEnvironmentDefault is not sufficient since that value is overwritten with the Bundle-RequiredExecutionEnvironment specified in a bundle's MANIFEST.MF.
For details in Tycho see org.eclipse.tycho.core.ee.ExecutionEnvironmentConfigurationImpl and org.eclipse.tycho.core.osgitools.AbstractTychoProject#readExecutionEnvironmentConfiguration(ReactorProject, MavenSession,ExecutionEnvironmentConfiguration)
I've verified only the mentioned configuration, but from what I've seen in Tycho's sources I expect building only products and features to work too.
If nothing else speaks against it I suggest to update the JustJ documentation and example product to primary use the mentioned configuration and keep the other ones only for those that cannot use Tycho 2.3.0.
Re: Working configuration to build products, plug-ins and features together [message #1841122 is a reply to message #1841086] Tue, 04 May 2021 09:04 Go to previous message
Thanks for the confirmation. I'll try to update the docs to talk about the newest version of Tycho first.
Previous Topic:Include additional certificates in JRE keystore
Next Topic:Legal Obligations when including a JRE from JustJ
Current Time: Sun Jul 13 23:21:51 EDT 2025
Powered by FUDForum. Page generated in 0.94969 seconds
