Home » Eclipse Projects » Memory Analyzer » Not A HPROF heap dump when parsing PHD files(Facing this errors while parsing PHD dumps using ParseHeapDump.sh on Linux)
Not A HPROF heap dump when parsing PHD files [message #1841058] Sun, 02 May 2021 17:05 Go to next message
Ruchir Verma is currently offline Ruchir VermaFriend
Hello!
I'm trying to parse PHD heap dumps using ParseHeapDump.sh on Linux and facing Not A HPROF heap dump.
I tried what's mentioned on the following link but no luck.
https://wiki.eclipse.org/MemoryAnalyzer/FAQ
I'm using Java 8, MAT 1.11 Linux version.
Re: Not A HPROF heap dump when parsing PHD files [message #1842224 is a reply to message #1841058] Sat, 12 June 2021 12:31 Go to previous message
I don't know what happened but your could try showing the OSGi console with the
-console -noExit
options on ParseHeapDump.shb, then do
ss org.eclipse.mat
and
ss com.ibm.dtfj
and see the state of the org.eclipse.mat.dtfj plugin.
Previous Topic:MAT command line with IBM PHD files?
Next Topic:Mat Linux Command Line Usage with Discard Feature
Current Time: Fri Feb 07 06:18:45 GMT 2025
Powered by FUDForum. Page generated in 0.05408 seconds
