Re: New Element Based Edge not working [message #1840897 is a reply to message #1840824] |
Wed, 28 April 2021 11:56 |
Hi !
I took a look on your metamodel screenshot and it seems that the feature owning the new FunctionExchange is "func_exchanges" and I see "func_exchange" in the properties view of the Create Instance lab::FunctionalExchange.
Florian
Re: New Element Based Edge not working [message #1840907 is a reply to message #1840900] |
Wed, 28 April 2021 15:15 |
When you perform Ctrl+space on the type Name field, do you see the FunctionalExchange type?
> The ports are within a container.
Indeed, I do not see all your metamodel but "self" might not be the right context (the eObject owning the func_exchanges feature). In your Change Context expression, you may need to go up to the container that will own the new functionalExchange. If you need, you can test your expressions by using the Interpreter View.
Florian
FUDForum. Page generated in 0.03890 seconds
