Home » Modeling » TMF (Xtext) » How to disable validation when editing in xtext editor?(validator performance)
How to disable validation when editing in xtext editor? [message #1840349] Tue, 13 April 2021 01:01 Go to next message
David Sun is currently offline David SunFriend
I have implemented a dsl editor based on xtext.
when the code of my dsl are more than 300 lines, the user experience of my xtext editor is getting slower and slower.
The xtext editor was blocked for serveral seconds when the validator was running.
How to disable validation when editing ? And How to enable validation after saving ?
Thanks!
Re: How to disable validation when editing in xtext editor? [message #1840350 is a reply to message #1840349] Tue, 13 April 2021 04:03 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
first you should profile where the time is spent and if validation is the problem at all.
second you should have a look at your check methods
and mark them with @Check(Check.NORMAL) instead of the default @Check which will be CheckType.FAST and be executed during editing. NORMAL will be executed on save
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: How to disable validation when editing in xtext editor? [message #1840351 is a reply to message #1840350] Tue, 13 April 2021 05:47 Go to previous messageGo to next message
Your advice works!
Thanks a lot!
Re: How to disable validation when editing in xtext editor? [message #1840383 is a reply to message #1840351] Tue, 13 April 2021 15:35 Go to previous message
Neeraj Bhusare is currently offline Neeraj BhusareFriend
David,
Please read the section "Creating Custom Validation Rules" from the Xtext documentation - https://www.eclipse.org/Xtext/documentation/103_domainmodelnextsteps.html
Twitter : @NeerajBhusare
Blog : https://nbhusare.github.io/
Best regards, Neeraj
Previous Topic:Qualified Name ID.ID....KEYWORD
Next Topic:Missing Rule BEGIN in White-space awareness grammar
Current Time: Fri Jun 09 04:19:25 GMT 2023
Powered by FUDForum. Page generated in 0.01456 seconds
