P2 Director Problem [message #1840331] |
Mon, 12 April 2021 17:53  |
Shortly after each time I start Eclipse 3-21 the eclipse updater opens to say "P2 Director (Eclipse IDE for JavaScript and Web Developers (2020-06))" needs to be manually installed. When I to do that there is a whole stream of red error messages about conflicts (I can add those if it will help?)
About the same time this started, I can no longer open .css files without Eclipse hanging.
Are these two problems related and if so what is the solution?
Thanks in anticipation.
Brian
Re: P2 Director Problem [message #1840332 is a reply to message #1840331] |
Mon, 12 April 2021 17:57   |
The error messages couldn't hurt, but then you should already have the P2 Director installed in a normal situation. What is "Eclipse 3-21" and where did it come from?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: P2 Director Problem [message #1840337 is a reply to message #1840332] |
Mon, 12 April 2021 19:00   |
Thanks for the swift response.
The Eclipse is 2021-03, not what I said before, sorry. It originally came from the Eclipse site but has been updated many times since. It is running on Linux Mint.
Please see attachment for first error massage.
Following is a copy & paste of the results:
Executing startup tasks
OpenJDK Runtime Environment 11.0.10+9-Ubuntu-0ubuntu1.20.04
Product org.eclipse.products.epp.package.javascript.2020-06
Workspace /home/b/dev/eclipsews
Bundle org.eclipse.oomph.setup 1.19.0.v20210223-0655, build=5032, branch=de1d74a6bf3addd102f8a873eabac293fbeaa3ad
Bundle org.eclipse.oomph.setup.core 1.20.0.v20210411-0650, build=5073, branch=1c11e00dca919bce9f672d8aae11ec1c2af4d45a
Bundle org.eclipse.oomph.setup.p2 1.16.0.v20200814-1205, build=4821, branch=9bc46599ffa5e6ffd3e2d2122913fe40d711f2f5
Performing P2 Director (Eclipse IDE for JavaScript and Web Developers (2020-06))
Offline = false
Mirrors = false
Resolving 17 requirements from 3 repositoriesto /home/b/eclipse/javascript-2020-06/eclipse
Requirement org.eclipse.equinox.p2.iu:epp.package.javascript [4.16.0,5.0.0)
Requirement org.eclipse.equinox.p2.iu:org.eclipse.platform.feature.group [4.16.0,5.0.0)
Requirement org.eclipse.equinox.p2.iu:org.eclipse.rcp.feature.group [4.16.0,5.0.0)
Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.gitflow.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.mpc.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.package.common.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.equinox.p2.user.ui.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.help.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.wikitext_feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.rse.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.tips.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.tm.terminal.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.wildwebdeveloper.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.wst.server_adapters.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.wst.server_ui.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.oomph.setup.feature.group
Repository http://download.eclipse.org/technology/epp/packages/2020-06
Repository http://download.eclipse.org/releases/2020-06/202006171000
Repository http://download.eclipse.org/oomph/updates/milestone/latest
Adding repository http://download.eclipse.org/technology/epp/packages/2020-06
Adding repository http://download.eclipse.org/releases/2020-06/202006171000
Adding repository http://download.eclipse.org/oomph/updates/milestone/latest
Calculating requirements and dependencies.
Cannot complete the request. Generating details.
ERROR: org.eclipse.equinox.p2.director code=10054 Cannot complete the install because of a conflicting dependency.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:291)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.resolve(ProfileTransactionImpl.java:428)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:899)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3851)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3794)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:5160)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2317)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:5154)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:5152)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3785)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3760)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3638)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:595)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:722)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1618253623015
ERROR: org.eclipse.equinox.p2.director code=1 Only one of the following can be installed at once:
ERROR: org.eclipse.equinox.p2.director code=0 Ant Build Tool Core 3.5.800.v20200608-1251 (org.eclipse.ant.core 3.5.800.v20200608-1251)
ERROR: org.eclipse.equinox.p2.director code=0 Ant Build Tool Core 3.5.700.v20191221-1203 (org.eclipse.ant.core 3.5.700.v20191221-1203)
ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1618253623015
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; epp.package.javascript [4.16.0,5.0.0)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.wildwebdeveloper.product 0.11.6.202103151818
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse IDE for JavaScript and Web Developers (includes incubating components) 4.16.0.20200615-1200 (epp.package.javascript 4.16.0.20200615-1200)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.platform.feature.group [4.16.0.v20200604-0951,4.16.0.v20200604-0951]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse Platform 4.16.0.v20200604-0951 (org.eclipse.platform.feature.group 4.16.0.v20200604-0951)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.ant.core [3.5.700.v20191221-1203,3.5.700.v20191221-1203]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse Platform 4.19.0.v20210303-1800 (org.eclipse.platform.feature.group 4.19.0.v20210303-1800)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.ant.core [3.5.800.v20200608-1251,3.5.800.v20200608-1251]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse IDE for JavaScript and Web Developers 0.11.6.202103151818 (org.eclipse.wildwebdeveloper.product 0.11.6.202103151818)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.platform.feature.group [4.19.0.v20210303-1800,4.19.0.v20210303-1800]
Took 2 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
Attachment: Error 1.png
(Size: 23.21KB, Downloaded 32 times)
Re: P2 Director Problem [message #1840363 is a reply to message #1840354] |
Tue, 13 April 2021 08:31   |
Thanks for the response Ed, but I am not clear what the solution is, can you humour me with answering a couple of more questions?
Bear in mind that I know little about Eclipse itself, I just use it as a tool. When I open it, it declares itself as 2021-03 on the splash screen.
Are you suggesting I just ignore the message and wait for the versions to catch up, or should I do a completely fresh install to ensure everything matches?
Is this connected with the other issue where now, each time I try to open a .css file, Eclipse freezes such that I have to force it to close?
Thanks for your patience with a newbie.
Brian
FUDForum. Page generated in 0.03977 seconds
