Home » Eclipse Projects » Eclipse Platform » Build from source problem(Could not resolve dependencies for project)
Build from source problem [message #1840261] Sat, 10 April 2021 08:46 Go to next message
Hello!
I wanted to build the Eclipse platform from the source codes for this manual: https://wiki.eclipse.org/Platform-releng/Platform_Build. Started building by checking dependencies (mvn -X clean validate) and got the following error:
[DEBUG] =======================================================================
[DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.300-SNAPSHOT/maven-metadata.xml in local (/home/main/.m2/repository)
[DEBUG] Dependency collection stats: {ConflictMarker.analyzeTime=78713, ConflictMarker.markTime=61270, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=24137, ConflictIdSorter.topsortTime=40652, ConflictIdSorter.conflictIdCount=1, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=1380744, ConflictResolver.conflictItemCount=1, DefaultDependencyCollector.collectTime=5510133, DefaultDependencyCollector.transformTime=1819431}
[DEBUG] org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG]    org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT:provided
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] eclipse-platform-parent 4.20.0-SNAPSHOT ............ SUCCESS [  4.167 s]
[INFO] eclipse-sdk-prereqs 4.20.0-SNAPSHOT ................ SUCCESS [  0.371 s]
[INFO] eclipse jdt 4.20.0-SNAPSHOT ........................ SUCCESS [  0.362 s]
[INFO] rt.equinox.framework 4.20.0-SNAPSHOT ............... SUCCESS [  0.370 s]
[INFO] org.eclipse.osgi 3.16.300-SNAPSHOT ................. SUCCESS [ 11.336 s]
[INFO] org.eclipse.osgi.util 3.6.0-SNAPSHOT ............... FAILURE [  0.295 s]
[INFO] org.eclipse.osgi.services 3.10.100-SNAPSHOT ........ SKIPPED
[INFO] rt.equinox.bundles 4.20.0-SNAPSHOT ................. SKIPPED
[INFO] org.eclipse.equinox.common 3.14.100-SNAPSHOT ....... SKIPPED
[ERROR] Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT
I post the logs and pom.xml from the root
Thanks for attention!
  • Attachment: logs.txt
    (Size: 5.56MB, Downloaded 204 times)
  • Attachment: pom.xml
    (Size: 2.38KB, Downloaded 227 times)
Re: Build from source problem [message #1840280 is a reply to message #1840261] Sun, 11 April 2021 07:35 Go to previous messageGo to next message
This is a pretty detailed question. It might be better to ask on the https://accounts.eclipse.org/mailing-list/platform-dev mailing list because that's were all the developers are. You might also offer to update the wiki based on your experience getting this actually working from the wiki's current instructions...
Re: Build from source problem [message #1844600 is a reply to message #1840280] Fri, 17 September 2021 05:45 Go to previous messageGo to next message
Hello!
was there a solution to this? I am having a similar issue.
[DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.200-SNAPSHOT/maven-metadata.xml in local (C:\Users\user\.m2\repository)
Long:
[INFO] ---------------< org.eclipse.osgi:org.eclipse.osgi.util >---------------
[INFO] Building org.eclipse.osgi.util 3.6.0-SNAPSHOT                   [60/501]
[INFO] ---------------------------[ eclipse-plugin ]---------------------------
[DEBUG] Resolving plugin prefix dependency from [org.apache.maven.plugins, org.codehaus.mojo]
[DEBUG] Resolved plugin prefix dependency to org.apache.maven.plugins:maven-dependency-plugin from POM org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG] Lifecycle default -> [validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy]
[DEBUG] Lifecycle clean -> [pre-clean, clean, post-clean]
[DEBUG] Lifecycle site -> [pre-site, site, post-site, site-deploy]
[DEBUG] === PROJECT BUILD PLAN ================================================
[DEBUG] Project:       org.eclipse.osgi:org.eclipse.osgi.util:3.6.0-SNAPSHOT
[DEBUG] Dependencies (collect): []
[DEBUG] Dependencies (resolve): [test]
[DEBUG] Repositories (dependencies): [eclipse (https://download.eclipse.org/eclipse/updates/4.19/R-4.19-202103031800/, p2, disa-bled), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] Repositories (plugins)     : [tycho-snapshots (https://repo.eclipse.org/content/repositories/tycho-snapshots/, default, releas-es+snapshots), cbi-jdt (https://repo.eclipse.org/content/repositories/eclipse-staging/, default, releases+snapshots), cbi-snapshots (https://repo.eclipse.org/content/repositories/cbi-snapshots/, default, releas-es+snapshots), cbi-releases (https://repo.eclipse.org/content/repositories/cbi-releases/, default, releases+snapshots), eclipse (https://repo.eclipse.org/content/repositories/cbi/, default, releases+snapshots), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] -----------------------------------------------------------------------
[DEBUG] Goal:          org.apache.maven.plugins:maven-dependency-plugin:2.8:tree (de-fault-cli)
[DEBUG] Style:         Regular
[DEBUG] Configuration: <?xml version="1.0" encoding="UTF-8"?>
<configuration>
  <appendOutput default-value="false">${appendOutput}</appendOutput>
  <excludes>${excludes}</excludes>
  <includes>${includes}</includes>
  <localRepository default-value="${localRepository}"/>
  <output>${output}</output>
  <outputFile>${outputFile}</outputFile>
  <outputType default-value="text">${outputType}</outputType>
  <scope>${scope}</scope>
  <skip default-value="false">${skip}</skip>
  <tokens default-value="standard">${tokens}</tokens>
  <verbose default-value="false">${verbose}</verbose>
  <project default-value="${project}"/>
</configuration>
[DEBUG] Dependency collection stats {ConflictMarker.analyzeTime=11101, ConflictMark-er.markTime=8700, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=3900, Con-flictIdSorter.topsortTime=8400, ConflictIdSorter.conflictIdCount=1, ConflictIdSort-er.conflictIdCycleCount=0, ConflictResolver.totalTime=91400, ConflictResolv-er.conflictItemCount=1, DefaultDependencyCollector.collectTime=1519601, DefaultDepend-encyCollector.transformTime=147199}
[DEBUG]    org.eclipse.osgi:org.eclipse.osgi:jar:3.16.200-SNAPSHOT:provided
[INFO]
[INFO] Skipping org.eclipse.equinox.common
[INFO] This project has been banned from the build due to previous failures.
Re: Build from source problem [message #1844628 is a reply to message #1844600] Sat, 18 September 2021 09:22 Go to previous message
The question was asked and discussed lengthily on platform-dev: https://www.eclipse.org/lists/platform-dev/msg02887.html
Previous Topic:Building with -Dnative=win32.win32.x86_64 fails
Next Topic:Buidling official Eclipse releases
Current Time: Sun Nov 02 15:24:36 EST 2025
Powered by FUDForum. Page generated in 0.02863 seconds
