Possible Bug Report for Single Select + Use Checkbox Combobox Cell Editors [message #1840042] |
Tue, 06 April 2021 06:06 |
Louis Detweiler Messages: 100 Registered: August 2017 |
We use NatTable in an RCP application we are developing and it is great!
We came across what we thought may be a bug involving the combination of using checkboxes in the Combobox cell editors while also NOT using multiselect.
However, we are currently using NatTable 1.5 so in order to ensure it wasn't already fixed in newer versions, as I couldn't specifically find it listed as a fixed bug in 1.6 and 2.0, I cloned the NatTable examples git repository.
In the example EditorExample in the package org.eclipse.nebula.widgets.nattable.examples.examples._110_Editing I changed the code in registerColumnTenComboBox (the City column) and set useCheckbox to true with the combo box.
I saw the same behavior we are seeing in our application, namely that sometimes the value is not changed even when you click on the check box. I've attached a video of what happens. (Sometimes the value is not updated to your selection, sometimes it is. If you deselect the value, then the next selection seems to always work)
Is this a known bug? I searched in the existing bug reports and could not find one for this issue.
Strangely, our Mac users have reported that the editing never works for them, whereas on Windows it does occasionally succeed at changing the value.
Louis
FUDForum. Page generated in 0.03968 seconds
