e(fx)clipse 3.7 + eclipse 2020/12 + open jdk 11 : Exception raised [message #1839900] |
Wed, 31 March 2021 09:22  |
after succeeding in using JavaFx in Eclipse 2020/06 (with java8) thanks to e(fx)clipse 3.6 I am trying now to migrate my project to Eclipse 2020/12 (java 11) and e(fx)clipse 3.7.
I try to display an FXViewPart, a snippet of my main class using JavaFx
public class MainView extends FXViewPart {
private WebView browser;
protected Scene createFxScene() {
browser = new WebView();
WebEngine webEngine = browser.getEngine();
webEngine.setJavaScriptEnabled(true);
I followed this link https://openjfx.io/openjfx-docs/#IDE-Intellij I am using openjfx 11 and my java version is :
openjdk version "11.0.8" 2020-07-14
OpenJDK Runtime Environment AdoptOpenJDK (build 11.0.8+10)
Eclipse OpenJ9 VM AdoptOpenJDK (build openj9-0.21.0, JRE 11 Windows 10 amd64-64-Bit Compressed References 20200715_679 (JIT enabled, AOT enabled)
OpenJ9 - 34cf4c075
OMR - 113e54219
JCL - 95bb504fbb based on jdk-11.0.8+10)
when I run my eclipse runtime to test my project I got this error :
here are my vm arguments
-Dorg.osgi.framework.bundle.parent=ext
--module-path "C:\Users\Asma\Downloads\openjfx-11.0.2_windows-x64_bin-sdk2\javafx-sdk-11.0.2\lib"
--add-modules javafx.controls,javafx.fxml,javafx.graphics
-Dosgi.framework.extensions=org.eclipse.fx.osgi
-Dsun.net.http.allowRestrictedHeaders=true
-Defxclipse.osgi.hook.debug=true
FXClassLoader#collectModifications - Reads: []
FXClassLoader#collectModifications - Exports: [javafx.graphics/com.sun.javafx.scene=BUNDLE(@299)]
FXClassLoader#collectModifications - Opens: [javafx.graphics/javafx.scene=BUNDLE(@299)]
FXClassLoader#advancedModuleLayerBoostrap - Using advanced layer creation to apply patches
JavaModuleLayerModification#applyConfigurations - Exporting 'javafx.graphics/com.sun.javafx.scene=BUNDLE(@299)'
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.eclipse.fx.osgi.fxloader.jpms.ModuleLayerWrapper$ControllerWrapper.addExports(ModuleLayerWrapper.java:173)
at org.eclipse.fx.osgi.fxloader.jpms.JavaModuleLayerModification.applyConfigurations(JavaModuleLayerModification.java:110)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.advancedModuleLayerBoostrap(FXClassLoader.java:483)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.initModuleLayer(FXClassLoader.java:426)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.getModuleLayer(FXClassLoader.java:293)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.findClassJavaFX11(FXClassLoader.java:207)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.postFindClass(FXClassLoader.java:144)
at org.eclipse.osgi.internal.loader.BundleLoader.searchHooks(BundleLoader.java:532)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:494)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:1078)
at org.eclipse.osgi.internal.framework.ContextFinder.loadClass(ContextFinder.java:142)
at java.base/java.lang.Class.forNameImpl(Native Method)
at java.base/java.lang.Class.forName(Class.java:412)
at java.xml/javax.xml.transform.FactoryFinder.getProviderClass(FactoryFinder.java:111)
at java.xml/javax.xml.transform.FactoryFinder.newInstance(FactoryFinder.java:165)
at java.xml/javax.xml.transform.FactoryFinder.find(FactoryFinder.java:257)
at java.xml/javax.xml.transform.TransformerFactory.newInstance(TransformerFactory.java:126)
at org.eclipse.jdt.internal.corext.util.History.save(History.java:299)
at org.eclipse.jdt.internal.corext.util.History.save(History.java:194)
at org.eclipse.jdt.internal.ui.JavaPlugin.stop(JavaPlugin.java:553)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:871)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:734)
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:863)
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:1025)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:370)
at org.eclipse.osgi.container.Module.doStop(Module.java:660)
at org.eclipse.osgi.container.Module.stop(Module.java:521)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1886)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1761)
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:275)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:202)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:220)
at java.base/java.lang.Thread.run(Thread.java:836)
Caused by: java.lang.reflect.InvocationTargetException
at jdk.internal.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.fx.osgi.fxloader.jpms.ModuleLayerWrapper$ControllerWrapper.addExports(ModuleLayerWrapper.java:170)
... 38 more
Caused by: java.lang.IllegalArgumentException: module javafx.graphics not in layer
at java.base/java.lang.ModuleLayer$Controller.ensureInLayer(ModuleLayer.java:216)
at java.base/java.lang.ModuleLayer$Controller.addExports(ModuleLayer.java:268)
... 42 more
FXClassLoader#postFindClass - exception while loading java.lang.reflect.InvocationTargetException. Continue delegation by returning NULL
... 38 more
... 42 more
Thanks a lot !
Re: e(fx)clipse 3.7 + eclipse 2020/12 + open jdk 11 : Exception raised [message #1849208 is a reply to message #1842051] |
Fri, 07 January 2022 16:03  |
Hi there,
Happy new year to all E(FX) users and committers.
Tom do you have any news on upgrading the platform that E(Fx) is running against ?
Recent LOG4J CVE showed us, it is important to keep up to date.
2019/12 is quite old now.
Stéphane.
Thomas Schindl wrote on Tue, 08 June 2021 10:49I'll check with our customers and see if they are ok lifting the platform but I would the go to 2021-06 which is going to be released fairly soon
FUDForum. Page generated in 0.04275 seconds
