Using 4DIAC in a simulation system [message #1839641] |
Thu, 25 March 2021 01:28 |
Neil Higgins Messages: 18 Registered: September 2016 Location: Brisbane |
I have an interesting proof-of-concept task for a power system controller. The controller would be implemented in IEC 61499, would export control commands to a power system simulator, and would import power system measurements from the power system simulator to complete the loop. The simulator has a COM API, somewhat dated, and some massaging of identifiers and values would be needed to map them between the simulator and the IEC 61499 environment.
For testing purposes, the IEC 61499 side would have to work in non-real-time, i.e. pause to await an update of the simulated power system quantities before proceeding. Because the power system simulator also has time-managed simulation capabilities, a common "simulated time" clock and (perhaps) a federated event queue would be desirable.
1. I assume that FORTE currently uses Linux time services in real-time(?) Is there an intervention mechanism, e.g. to substitute a different "clock" which would appropriately affect event and time management in FORTE? If not, does anyone want to provide hints as to which parts of the source code I should look at?
2. As mentioned in another post, I am looking at MQTT as the IPC mechanism between the power system simulator and FORTE, although this would be crude and less-than-ideal. Access to the Lua code for one or more dynamic types would provide a much more flexible alternative. Is there some way that this might be enabled?
FUDForum. Page generated in 0.03979 seconds
