Home » Language IDEs » C / C++ IDE (CDT) » Run configuration(Unable to run more than once)
Run configuration [message #1839629] Wed, 24 March 2021 20:02
Sudhindra Gopal Krishna is currently offline Sudhindra Gopal KrishnaFriend
I really would like to get some help with this issue that most of my students are facing.
This is a data structures class they all are using Eclipse CDT as the editor/compiler for their projects.
The project is about handling double pointers and I do not know if their programs are causing errors in the console or the eclipse setup itself. The program runs fine on the terminal.
To overcome the issue, some students suggested that they create run configurations every time they run the project, may I know if there is a workaround to this issue?
Any help would be appreciated.
Thank you,
Sudhindra Gopal
Previous Topic:Draw a line over function definitions?
Next Topic:Cannot have expected output for producerconsumer (bounded-buffer) problem
Current Time: Wed Dec 07 19:57:48 GMT 2022
Powered by FUDForum. Page generated in 0.02028 seconds
