Home » Newcomers » Newcomers » Eclipse keeps crashing(java was started but returned exit code=-805306369)
Eclipse keeps crashing [message #1839592] |
Wed, 24 March 2021 10:33 |
Nuchem Katz Messages: 11 Registered: March 2021 |
I wondered if anyone could help me please and many thanks for your support, in advance.
My eclipse IDE keeps crashing. Below are screenshots of the messages that appear and contents in the log file which keep showing up and which I think are mostly relevant (They all seem to be just warning so I don't understand why it crashes).
I also tried fixing it by deleting the .metadata folder and by running eclipse with -clean option. I don't want to uninstall eclipse yet because I've done quite a lot of configuration and plugin installments.
This is the content of the log file that keeps from the time of the last crash:
!ENTRY org.eclipse.core.resources 2 10035 2021-03-24 10:24:37.648
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2021-03-24 10:24:38.960
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2021-03-24 10:24:38.960
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@8aafd70,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@3c717ef2,
,,true),null),
!MESSAGE A conflict occurred for ALT+CTRL+P:
Binding(ALT+CTRL+P,
ParameterizedCommand(Command(org.eclipse.m2e.profiles.ui.commands.selectMavenProfileCommand,Select Maven Profiles,
Category(org.eclipse.ui.category.window,Window,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7ca0b05e,
,,true),null),
Binding(ALT+CTRL+P,
ParameterizedCommand(Command(org.jboss.tools.maven.ui.commands.selectMavenProfileCommand,Maven Profiles Selection,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@3e5ed0d4,
,,true),null),
!ENTRY org.eclipse.jface.text 2 0 2021-03-24 10:24:40.413
!MESSAGE Duplicate template id: 'org.eclipse.wst.xslt.templates.xpath.number'
!MESSAGE Duplicate template id: 'org.eclipse.wst.xslt.templates.xpath.round'
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:41.530
!MESSAGE Entering DelegatingStreamConnectionProvider()
!MESSAGE DelegatingStreamConnectionProvider classloader = org.eclipse.osgi.internal.loader.EquinoxClassLoader@76fece79[org.springframework.tooling.boot.ls:1.24.0.202012131915(id=871)]
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:41.546
!MESSAGE SpringBootLanguageServer exists!
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:41.577
!MESSAGE Instantiating ReusableClasspathListenerHandler
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:43.886
!MESSAGE Boot LS startup time from start to initialized: 2323ms
!ENTRY org.eclipse.egit.ui 2 0 2021-03-24 10:24:44.000
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\nuche'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.jboss.tools.maven.profiles.ui 1 0 2021-03-24 10:24:44.004
!MESSAGE Found org.eclipse.m2e.profiles.ui, removing conflicting binding for org.jboss.tools.maven.ui.commands.selectMavenProfileCommand
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.023
!MESSAGE ClasspathListenerHandler addClasspathListener sts4.classpath.qfiSaiwRisBatched = true
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.026
!MESSAGE Setting up ClasspathListenerManager
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.028
!MESSAGE Scheduling initial event for all projects ...
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.029
!MESSAGE Scheduling initial event for all projects DONE
!MESSAGE exists = true open = true => deleted = false
!MESSAGE ClasspathListenerHandler addClasspathListener sts4.classpath.qfiSaiwR => OK
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.057
!MESSAGE classpath=128 entries
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.063
!MESSAGE buffering callback sts4.classpath.qfiSaiwR biddingSoft false 128
!MESSAGE executing callback sts4.classpath.qfiSaiwR 1 batched events
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-24 10:24:44.186
!MESSAGE executing callback sts4.classpath.qfiSaiwR SUCCESS [done]
I used to also see this one but I followed what's advised in the first response and it now seems to have gone: https://stackoverflow.com/questions/8823677/javadoc-not-available-in-eclipse/33779933
!ENTRY org.eclipse.lsp4e 2 0 2021-03-24 09:30:45.271
!MESSAGE Javadoc unavailable. Failed to obtain it.
!STACK 0
java.lang.InterruptedException
at java.base/java.util.concurrent.CompletableFuture.reportGet(CompletableFuture.java:385)
at java.base/java.util.concurrent.CompletableFuture.get(CompletableFuture.java:2086)
at org.eclipse.lsp4e.jdt.LSJavaHoverProvider.getHoverInfo2(LSJavaHoverProvider.java:70)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:163)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:130)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaEditorTextHoverProxy.getHoverInfo2(JavaEditorTextHoverProxy.java:89)
at org.eclipse.jface.text.TextViewerHoverManager$1.run(TextViewerHoverManager.java:155)
!SESSION 2021-03-24 09:44:55.395 -----------------------------------------------
eclipse.buildId=4.18.0.I20201202-1800
java.version=15.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Re: Eclipse keeps crashing [message #1839596 is a reply to message #1839592] |
Wed, 24 March 2021 12:07 |
UPDATE:
I noticed that it happens a lot when I navigate within the Outline tab of a given open source file in eclipse, to jump quickly from one method or variable to another.
As well as the above, I also tried switching to a new workspace in case the old was corrupt.
[Updated on: Wed, 24 March 2021 12:12] Report message to a moderator
Re: Eclipse keeps crashing [message #1839608 is a reply to message #1839604] |
Wed, 24 March 2021 15:08 |
You mean, you'd wait a bit after starting it before using it (or in my case before using the Outline tab) and then use it no problem? Interesting, now that you've said it, I tried operating the Outline and it didn't crash. You're right, I also noticed, when I start operating the Outline, intensively, immediately after restarting, it crashes much faster than when operating it a while after.
So, I didn't say the JVM crashed. I thought it's eclipse.
Also (not sure if it's related) I initially had JRE 15 but for some reason I kept getting warnings that JRE 11 must be used (I'll post a screenshot next time it happens) so I changed to 11 (by changing the JRE system library in the build path from jdk-15 to using jdk-11) BUT now eclipse keeps automatically reverting it to 15 (JavaSE -11 (JDK-15.0.2) ) every time I restart the IDE.
Momentarily it is on JDK-15 fully (also JRE) and I'll look-out (not) for the next crash. In any event, thanks so much for your tip.
P.S. As well as the above, I also tried switching to a new workspace in case the old was corrupt.
I'm just wondering whether it's worth trying to uninstall eclipse. I use it with maven and spring-boot.
Re: Eclipse keeps crashing [message #1839653 is a reply to message #1839644] |
Thu, 25 March 2021 09:01 |
Ed, thanks for your comment. I updated it (I thought the whole time I had the latest version) but of no avail. As soon as I just hover over the Outline panel, eclipse freezes for good - until I quit and re-open it. After quitting, eclipse pops up an error window as per the attached.
Nothing much changed in the log:
!SESSION 2021-03-25 08:57:14.504 -----------------------------------------------
eclipse.buildId=4.19.0.I20210303-1800
java.version=15.0.2
!ENTRY org.eclipse.jface 2 0 2021-03-25 08:57:17.978
!SUBENTRY 1 org.eclipse.jface 2 0 2021-03-25 08:57:17.978
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2b76ecd5,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7bd7c4cf,
,,true),null),
Binding(ALT+CTRL+P,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5b9df3b3,
,,true),null),
Binding(ALT+CTRL+P,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@67b20b4c,
,,true),null),
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:21.697
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:21.698
!MESSAGE DelegatingStreamConnectionProvider classloader = org.eclipse.osgi.internal.loader.EquinoxClassLoader@242bd3a7[org.springframework.tooling.boot.ls:1.25.0.202103111026(id=1126)]
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:21.700
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:21.719
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.222
!MESSAGE Boot LS startup time from start to initialized: 2518ms
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.315
!MESSAGE ClasspathListenerHandler addClasspathListener sts4.classpath.wtWWYNprisBatched = true
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.317
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.319
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.320
!MESSAGE ClasspathListenerHandler addClasspathListener sts4.classpath.wtWWYNpr => OK
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.328
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.333
!MESSAGE buffering callback sts4.classpath.wtWWYNpr biddingSoft false 128
!MESSAGE executing callback sts4.classpath.wtWWYNpr 1 batched events
!ENTRY org.jboss.tools.maven.profiles.ui 1 0 2021-03-25 08:57:24.520
!ENTRY org.springframework.tooling.ls.eclipse.commons 1 0 2021-03-25 08:57:24.741
!MESSAGE executing callback sts4.classpath.wtWWYNpr SUCCESS [done]
P.S. the build path was automatically updated back to JavaSE-11 (JDK 11.0.10) Not sure why.
Re: Eclipse keeps crashing [message #1839658 is a reply to message #1839653] |
Thu, 25 March 2021 09:55 |
I was too tempted and uninstalled eclipse, re-installed it and the problem's gone. It actually doesn't seem like I'll have to do much work at all - now that I know what configurations I need and how to do it. installing spring boot from market place, download repository index and rebuild etc.
Thanks everyone for the help though.
[Updated on: Thu, 25 March 2021 10:13] Report message to a moderator
Current Time: Wed Apr 24 17:27:24 GMT 2024
Powered by FUDForum. Page generated in 0.09122 seconds
