Home » Newcomers » Newcomers » Eclipse crashes on any git operation
Eclipse crashes on any git operation [message #1839480] Mon, 22 March 2021 11:24 Go to next message
Jean-Yves Toumit is currently offline Jean-Yves ToumitFriend
Hi all,
I cannot do any git operation anymore, and get the following error:
(Eclipse:4186): GLib-GIO-CRITICAL **: 12:01:53.767: g_dbus_proxy_get_object_path: assertion 'G_IS_DBUS_PROXY (proxy)' failed
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007eff9ca87660, pid=4186, tid=18671
# JRE version: OpenJDK Runtime Environment (11.0.10+9) (build 11.0.10+9-Ubuntu-0ubuntu1.18.04)
# Java VM: OpenJDK 64-Bit Server VM (11.0.10+9-Ubuntu-0ubuntu1.18.04, mixed mode, sharing, tiered, compressed oops, g1 gc, linux-amd64)
# Problematic frame:
# C [libglib-2.0.so.0+0x3b660] g_str_hash+0x0
# Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport %p %s %c %d %P %E" (or dumping to /jytoussd/progs/eclipse/core.4186)
# An error report file with more information is saved as:
# /jytoussd/progs/eclipse/hs_err_pid4186.log
# If you would like to submit a bug report, please visit:
# https://bugs.launchpad.net/ubuntu/+source/openjdk-lts
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
This happens the moment I click OK to submit my git credentials.
Eclipse is updated regularly, currently:
Version: 2021-03 (4.19.0)
Build id: 20210312-0638
Git on the command line runs fine.
This has only happened recently, probably after an update. I'm also attaching the error report file which clearly shows the crash happens in sshd.
Any ideas how I can fix this?
JY.
Re: Eclipse crashes on any git operation [message #1839492 is a reply to message #1839480] Mon, 22 March 2021 16:47 Go to previous messageGo to next message
Thomas Wolf is currently offline Thomas WolfFriend
Nope, the crash is not in sshd, it is in the Equinox secure storage.
Please open a bug report. There have been many changes in this secure storage component in Eclipse 2021-03.
Re: Eclipse crashes on any git operation [message #1839498 is a reply to message #1839492] Mon, 22 March 2021 19:39 Go to previous message
Done, thanks!
Previous Topic:eclipse installer problem
Next Topic:How to solve this problem?
Current Time: Fri Jun 18 22:27:16 GMT 2021
Powered by FUDForum. Page generated in 0.03349 seconds
