Home » Eclipse Projects » GEF » Zest (Problems with Drag and Drop after upgrade)
Zest [message #1839390] Fri, 19 March 2021 14:17 Go to next message
I recently upgraded our eclipse rcp app which uses gef zest sdk (org.eclipse.gef.zest.sdk.feature) from version 5.0.2.201901221055
to 5.1.2.202012080300. The graph part of our application no longer works.
The graph is drawn correctly, but as soon as I click on a node and try to move it a large number of exceptions are generated. The same problem occurred for me when I tried to run the JFaceFontsExample (from org.eclipse.gef.zest.examples.jface).
The first exception generated is this:
java.lang.IllegalStateException: java.lang.IllegalArgumentException: Not enough bend points supplied!
	at org.eclipse.gef.mvc.fx.policies.BendConnectionPolicy.locallyExecuteOperation(BendConnectionPolicy.java:587)
	at org.eclipse.gef.mvc.fx.policies.AbstractPolicy.commit(AbstractPolicy.java:67)
	at org.eclipse.gef.mvc.fx.policies.BendConnectionPolicy.commit(BendConnectionPolicy.java:134)
	at org.eclipse.gef.mvc.fx.handlers.ConnectedSupport.commit(ConnectedSupport.java:90)
	at org.eclipse.gef.mvc.fx.handlers.TranslateSelectedOnDragHandler.endDrag(TranslateSelectedOnDragHandler.java:152)
	at org.eclipse.gef.zest.fx.handlers.TranslateSelectedAndRelocateLabelsOnDragHandler.endDrag(TranslateSelectedAndRelocateLabelsOnDragHandler.java:54)
	at org.eclipse.gef.mvc.fx.gestures.ClickDragGesture.release(ClickDragGesture.java:438)
	at org.eclipse.gef.mvc.fx.gestures.ClickDragGesture$1.handle(ClickDragGesture.java:135)
	at org.eclipse.gef.mvc.fx.gestures.ClickDragGesture$1.handle(ClickDragGesture.java:1)
	at javafx.base/com.sun.javafx.event.CompositeEventHandler$NormalEventFilterRecord.handleCapturingEvent(CompositeEventHandler.java:282)
	at javafx.base/com.sun.javafx.event.CompositeEventHandler.dispatchCapturingEvent(CompositeEventHandler.java:98)
	at javafx.base/com.sun.javafx.event.EventHandlerManager.dispatchCapturingEvent(EventHandlerManager.java:223)
	at javafx.base/com.sun.javafx.event.EventHandlerManager.dispatchCapturingEvent(EventHandlerManager.java:180)
	at javafx.base/com.sun.javafx.event.CompositeEventDispatcher.dispatchCapturingEvent(CompositeEventDispatcher.java:43)
	at javafx.base/com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:52)
	at org.eclipse.gef.fx.swt.canvas.FXCanvasEx$EventDispatcherEx.dispatchEvent(FXCanvasEx.java:155)
	at javafx.base/com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
	at javafx.base/com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
	at javafx.base/com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
	at javafx.base/com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
	at javafx.base/javafx.event.Event.fireEvent(Event.java:198)
	at javafx.graphics/javafx.scene.Scene$MouseHandler.process(Scene.java:3851)
	at javafx.graphics/javafx.scene.Scene$MouseHandler.access$1200(Scene.java:3579)
	at javafx.graphics/javafx.scene.Scene.processMouseEvent(Scene.java:1849)
	at javafx.graphics/javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2588)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedScene.lambda$mouseEvent$4(EmbeddedScene.java:286)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedScene.lambda$mouseEvent$5(EmbeddedScene.java:279)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:428)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:427)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3624)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
	at org.wcs.smart.SmartApp.start(SmartApp.java:47)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1434)
Caused by: java.lang.IllegalArgumentException: Not enough bend points supplied!
	at org.eclipse.gef.mvc.fx.parts.IBendableContentPart.setVisualBendPoints(IBendableContentPart.java:587)
	at org.eclipse.gef.mvc.fx.operations.BendVisualOperation.execute(BendVisualOperation.java:56)
	at org.eclipse.gef.mvc.fx.policies.BendConnectionPolicy.locallyExecuteOperation(BendConnectionPolicy.java:585)
	... 55 more
	at org.eclipse.gef.mvc.fx.handlers.AbstractHandler.restoreRefreshVisuals(AbstractHandler.java:256)
	at org.eclipse.gef.mvc.fx.handlers.TranslateSelectedOnDragHandler.abortDrag(TranslateSelectedOnDragHandler.java:67)
	at org.eclipse.gef.zest.fx.handlers.TranslateSelectedAndRelocateLabelsOnDragHandler.abortDrag(TranslateSelectedAndRelocateLabelsOnDragHandler.java:37)
	at org.eclipse.gef.mvc.fx.gestures.ClickDragGesture.doAbortPolicies(ClickDragGesture.java:236)
	at org.eclipse.gef.mvc.fx.gestures.AbstractGesture.abortPolicies(AbstractGesture.java:66)
	at org.eclipse.gef.mvc.fx.gestures.ClickDragGesture.abortPolicies(ClickDragGesture.java:228)
	at org.eclipse.gef.mvc.fx.gestures.AbstractGesture$1.changed(AbstractGesture.java:124)
	at org.eclipse.gef.mvc.fx.gestures.AbstractGesture$1.changed(AbstractGesture.java:1)
	at javafx.base/com.sun.javafx.binding.ExpressionHelper$Generic.fireValueChangedEvent(ExpressionHelper.java:360)
	at javafx.base/com.sun.javafx.binding.ExpressionHelper.fireValueChangedEvent(ExpressionHelper.java:80)
	at javafx.base/javafx.beans.property.ReadOnlyBooleanPropertyBase.fireValueChangedEvent(ReadOnlyBooleanPropertyBase.java:72)
	at javafx.base/javafx.beans.property.ReadOnlyBooleanWrapper.fireValueChangedEvent(ReadOnlyBooleanWrapper.java:103)
	at javafx.base/javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:111)
	at javafx.base/javafx.beans.property.BooleanPropertyBase.access$000(BooleanPropertyBase.java:50)
	at javafx.base/javafx.beans.property.BooleanPropertyBase$Listener.invalidated(BooleanPropertyBase.java:239)
	at javafx.base/com.sun.javafx.binding.ExpressionHelper$SingleInvalidation.fireValueChangedEvent(ExpressionHelper.java:136)
	at javafx.base/javafx.beans.binding.BooleanBinding.invalidate(BooleanBinding.java:174)
	at org.eclipse.gef.mvc.fx.viewer.InfiniteCanvasViewer.onWindowFocusedChanged(InfiniteCanvasViewer.java:486)
	at org.eclipse.gef.mvc.fx.viewer.InfiniteCanvasViewer.access$6(InfiniteCanvasViewer.java:484)
	at org.eclipse.gef.mvc.fx.viewer.InfiniteCanvasViewer$3.changed(InfiniteCanvasViewer.java:99)
	at org.eclipse.gef.mvc.fx.viewer.InfiniteCanvasViewer$3.changed(InfiniteCanvasViewer.java:1)
	at javafx.base/javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:145)
	at javafx.graphics/javafx.stage.Window.setFocused(Window.java:674)
	at javafx.graphics/javafx.stage.Window$1.setFocused(Window.java:149)
	at javafx.graphics/com.sun.javafx.stage.WindowHelper.setFocused(WindowHelper.java:112)
	at javafx.graphics/com.sun.javafx.stage.WindowPeerListener.changedFocused(WindowPeerListener.java:64)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedStage.lambda$setFocused$4(EmbeddedStage.java:270)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedStage.lambda$notifyStageListener$0(EmbeddedStage.java:226)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedStage.notifyStageListener(EmbeddedStage.java:225)
	at javafx.graphics/com.sun.javafx.tk.quantum.EmbeddedStage.setFocused(EmbeddedStage.java:276)
	at javafx.swt/javafx.embed.swt.FXCanvas.sendFocusEventToFX(FXCanvas.java:1060)
	at javafx.swt/javafx.embed.swt.FXCanvas.access$500(FXCanvas.java:141)
	at javafx.swt/javafx.embed.swt.FXCanvas$5.focusLost(FXCanvas.java:564)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:147)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1042)
	at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2960)
	at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1849)
	at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:5185)
	at org.eclipse.swt.widgets.Canvas.WM_KILLFOCUS(Canvas.java:421)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4796)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4938)
	at org.eclipse.swt.internal.win32.OS.PeekMessage(Native Method)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
!ENTRY org.eclipse.ui 4 0 2021-03-19 10:51:32.854
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalStateException: Not yet initialized!
	at org.eclipse.gef.mvc.fx.policies.AbstractPolicy.checkInitialized(AbstractPolicy.java:39)
	at org.eclipse.gef.mvc.fx.policies.AbstractPolicy.commit(AbstractPolicy.java:60)
	at org.eclipse.gef.mvc.fx.policies.TransformPolicy.commit(TransformPolicy.java:124)
	at org.eclipse.gef.mvc.fx.handlers.AbstractHandler.commit(AbstractHandler.java:130)
	at org.eclipse.gef.mvc.fx.handlers.TranslateSelectedOnDragHandler.endDrag(TranslateSelectedOnDragHandler.java:141)
	at javafx.base/com.sun.javafx.event.EventQueue.fire(EventQueue.java:48)
	at javafx.graphics/javafx.scene.Scene$MouseHandler.handleEnterExit(Scene.java:3770)
	at javafx.graphics/javafx.scene.Scene$MouseHandler.process(Scene.java:3836)
	at javafx.graphics/javafx.scene.Scene$MouseHandler$1.run(Scene.java:3615)
Has anybody else seen this or have a solution for me?
Emily
Re: Zest [message #1843986 is a reply to message #1839390] Thu, 26 August 2021 03:53 Go to previous messageGo to next message
i caught this problem as same as you.my solution is to lower your gef version,and this problem resovled.you can use a eclipse package without installing gef,then install gef 5.0.xx version instead of newer version like 5.2.xx version.
Re: Zest [message #1843988 is a reply to message #1839390] Thu, 26 August 2021 04:06 Go to previous message
No Message Body
[Updated on: Thu, 26 August 2021 04:09] by Moderator
Previous Topic:GEF update site not available
Next Topic:Circle shape is shown as oval, anyone encountered this?
Current Time: Mon May 19 14:55:35 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
