javax.annotation : osgi uses constraint violation [message #1839140] |
Mon, 15 March 2021 15:20 |
khalid kherrazi Messages: 2 Registered: March 2021 |
Hello all,
i have an app using an embedded jetty server with rest compatibility with jax-rs and glassfish.jersey for supporting multipart forms.
I updated rcp from 4.6 to 4.14 ( embeded jetty server from v9.3.9 to v9.4.24 ) and glassfish.jersey from v2.25.1 to v2.33
it compile fine but when starting the app, osgi does not succeed to resolve my plugin because of a uses constraint violation of 'javax.annotation'.
i'm getting this error :
org.osgi.framework.BundleException: Impossible de résoudre le module :myRestPlugin[832]
Bundle was not resolved because of a uses constraint violation.
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource myRestPlugin [osgi.identity; osgi.identity="myRestPlugin"; type="osgi.bundle"; version:Version="1.0.0.qualifier"] because it is exposed to package 'javax.annotation' from resources org.eclipse.osgi [osgi.identity; osgi.identity="org.eclipse.osgi"; type="osgi.bundle"; version:Version="3.15.100.v20191114-1701"; singleton:="true"] and javax.annotation-api [osgi.identity; osgi.identity="javax.annotation-api"; type="osgi.bundle"; version:Version="1.3.2"] via two dependency chains.
Chain 1:
require: (osgi.wiring.bundle=org.eclipse.osgi)
provide: osgi.wiring.bundle: [org.eclipse.osgi, system.bundle]
Chain 2:
require: (&(osgi.wiring.bundle=org.glassfish.jersey.media.jersey-media-multipart)(bundle-version>=2.33.0))
provide: osgi.wiring.bundle; bundle-version:Version="2.33.0"; osgi.wiring.bundle="org.glassfish.jersey.media.jersey-media-multipart"
org.glassfish.jersey.media.jersey-media-multipart [osgi.identity; osgi.identity="org.glassfish.jersey.media.jersey-media-multipart"; type="osgi.bundle"; version:Version="2.33.0"]
import: (&(osgi.wiring.package=org.glassfish.jersey.internal.util)(&(version>=2.33.0)(!(version>=3.0.0))))
export: osgi.wiring.package=org.glassfish.jersey.internal.util; uses:=javax.annotation
org.glassfish.jersey.core.jersey-common [osgi.identity; osgi.identity="org.glassfish.jersey.core.jersey-common"; type="osgi.bundle"; version:Version="2.33.0"]
import: (&(osgi.wiring.package=javax.annotation)(&(version>=1.2.0)(!(version>=3.0.0))))
export: osgi.wiring.package: javax.annotation
at org.eclipse.osgi.container.Module.start(Module.java:462)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1844)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1837)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1780)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1742)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1664)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
the java version is 1.8.
It would be highly appreciated if someone has any tip for me how to solve this.
Thanks a lot !
[Updated on: Mon, 15 March 2021 23:12] Report message to a moderator
FUDForum. Page generated in 0.03455 seconds
