Home » Eclipse Projects » Eclipse Platform » Help with The library with the namespace "xyz" is not found. error(Help with The library with the namespace "xyz" is not found. error)
Help with The library with the namespace "xyz" is not found. error [message #1839032] Thu, 11 March 2021 10:41
I have this in the BIRT forum as well, but not getting any feedback, so adding it here as well.
Not sure I have the lingo and understanding of relationship of Eclipse and BIRT, but here goes.
I have a laptop A, that has eclipse installed that I use with BIRT. I upgraded eclipse to the Neon version. I took my Eclipse/BIRT folder on laptop A and zipped it up and put it on a thumb drive.
I then extracted it over on Laptop B.
Eclipse starts up fine on Laptop B, and I can view a BIRT report.
When I go to run it, I get the following error :
On Laptop A , in my Eclipse/BIRT install folder I see
BIRT_4.6\eclipse\reports_source\birt\libraries\MaximoSystemLibrary.rptlibrary
and BIRT_4.6\eclipse\reports_source\birt\libraries\MaximoSystemLibrary_org.rptlibrary
and these libraries are also in the folder on Laptop B.
Can anyone, in the simplest terms, explain what I need to do to resolve this issue ? Thanks.
Previous Topic:Building the "Eclipse IDE for Java Developers" from source
Next Topic:how to link with putty using eclipse
Current Time: Sun May 18 06:34:39 EDT 2025
Powered by FUDForum. Page generated in 0.03421 seconds
