Re: Referenced DSL-Files are not recognized on clean [message #1838556 is a reply to message #1838555] |
Mon, 01 March 2021 12:08 |
Christian Sodomka Messages: 19 Registered: May 2019 |
We used the following code:
package at.ama.swm.tabs.scoping
import com.google.inject.Inject
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.resource.impl.ResourceDescriptionsProvider
import at.ama.swm.tabs.tabs.TabsPackage
class TabsIndex {
@Inject ResourceDescriptionsProvider rdp
def getResourceDescription(EObject eObj) {
val index = rdp.getResourceDescriptions(eObj.eResource)
index.getResourceDescription(eObj.eResource.URI)
def getExportedEObjectDescriptions(EObject eObj) {
eObj.getResourceDescription.getExportedObjects
def getExportedClassesEObjectDescriptions(EObject eObj) {
eObj.getResourceDescription.getExportedObjectsByType(TabsPackage.eINSTANCE.project)
and
* generated by Xtext 2.16.0
import at.ama.swm.tabs.tabs.Process
import at.ama.swm.tabs.tabs.TabsProcess
import at.ama.swm.tabs.tabs.TabsProgram
import org.eclipse.emf.common.util.BasicEList
import org.eclipse.emf.common.util.EList
import org.eclipse.emf.ecore.EReference
import org.eclipse.xtext.scoping.IScope
* This class contains custom scoping description.
* See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
* on how and when to use it.
class TabsScopeProvider extends AbstractTabsScopeProvider {
val ePackage = TabsPackage.eINSTANCE
override getScope(EObject context, EReference reference) {
// Symbols - Variables & In/Out Parameters
if (reference == ePackage.symbolRef_Value || reference == ePackage.resultRef_Symbol) {
return scopeForSymbolRef(context)
// use - only valid in current process
else if (reference == ePackage.call_Ref) {
return scopeForUseRef(context)
else if (reference == ePackage.processCall_Ref) {
else if (reference == ePackage.call_Fqn) {
// global var defs
else if (reference == ePackage.qualifiedVariable_Struct) {
return scopeForGlobalRef(context)
return super.getScope(context, reference)
def protected IScope scopeForGlobalRef(EObject context) {
val container = context.eContainer
return switch (container) {
TabsProgram: {
IgnoreCaseScopes.scopeFor(container.proc.using)
default: scopeForGlobalRef(container)
def protected IScope scopeForUseRef(EObject context) {
TabsProcess: {
IgnoreCaseScopes.scopeFor(container.using)
default: scopeForUseRef(container)
* calculate the Scope for Symbol References
* Seite 249 im Buch!
def protected IScope scopeForSymbolRef(EObject context) {
Process: {
var EList<EObject> symbolList = new BasicEList()
symbolList.addAll(container.variables)
symbolList.addAll(container.parameter)
IgnoreCaseScopes.scopeFor(symbolList)
default: scopeForSymbolRef(container)
and for ignore case:
* Cope of org.eclipse.xtext.scoping.Scopes
* THE ESSENTIAL DIFFERENCE:
* SimpleScope() is created with last param boolean ignoreCase set to true
package at.ama.swm.tabs.scoping;
import java.util.ArrayList;
import java.util.Map;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.EcoreUtil2;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.resource.EObjectDescription;
import org.eclipse.xtext.resource.IEObjectDescription;
import org.eclipse.xtext.scoping.IScope;
import org.eclipse.xtext.scoping.impl.SimpleScope;
import org.eclipse.xtext.util.SimpleAttributeResolver;
import com.google.common.base.Function;
import com.google.common.base.Predicate;
import com.google.common.base.Predicates;
import com.google.common.collect.Iterables;
import com.google.common.collect.LinkedHashMultimap;
import com.google.common.collect.Lists;
import com.google.common.collect.Maps;
import com.google.common.collect.Multimap;
* This class contains static utility functions to create and work on {@link IScope} and {@link IEObjectDescription}
* @author Sven Efftinge - Initial contribution and API
* @author Jan Koehnlein - introduced QualifiedName
public class IgnoreCaseScopes {
public static Iterable<IEObjectDescription> selectCompatible(Iterable<IEObjectDescription> exportedObjects, final EClass clazz) {
return Iterables.filter(exportedObjects, new Predicate<IEObjectDescription>() {
public boolean apply(IEObjectDescription input) {
return EcoreUtil2.isAssignableFrom(clazz,input.getEClass());
* creates a scope using {@link SimpleAttributeResolver#NAME_RESOLVER} to compute the names and sets
* {@link IScope#NULLSCOPE} as parent scope
public static IScope scopeFor(Iterable<? extends EObject> elements) {
return scopeFor(elements, IScope.NULLSCOPE);
public static IScope scopeFor(Iterable<? extends EObject> elements, IScope outer) {
return scopeFor(elements, QualifiedName.wrapper(SimpleAttributeResolver.NAME_RESOLVER), outer);
* creates a scope using the passed function to compute the names and sets the passed scope as the parent scope
public static <T extends EObject> IScope scopeFor(Iterable<? extends T> elements,
final Function<T, QualifiedName> nameComputation, IScope outer) {
return new SimpleScope(outer,scopedElementsFor(elements, nameComputation), true);
* transforms an {@link Iterable} of {@link EObject}s into an {@link Iterable} of {@link IEObjectDescription}s computing
* the {@link EAttribute} 'name' to compute the {@link IEObjectDescription}'s name. If not existent the object is
* filtered out.
public static Iterable<IEObjectDescription> scopedElementsFor(Iterable<? extends EObject> elements) {
return scopedElementsFor(elements, QualifiedName.wrapper(SimpleAttributeResolver.NAME_RESOLVER));
* the name of the elements using the passed {@link Function} If the passed function returns null the object is
* filtered out.
public static <T extends EObject> Iterable<IEObjectDescription> scopedElementsFor(Iterable<? extends T> elements,
final Function<T, QualifiedName> nameComputation) {
Iterable<IEObjectDescription> transformed = Iterables.transform(elements,
new Function<T, IEObjectDescription>() {
public IEObjectDescription apply(T from) {
final QualifiedName qualifiedName = nameComputation.apply(from);
if (qualifiedName != null)
return new EObjectDescription(qualifiedName, from, null);
return null;
return Iterables.filter(transformed, Predicates.notNull());
* indexes the IEObject description using the given
public static <T> Multimap<T,IEObjectDescription> index(Iterable<IEObjectDescription> descriptions, Function<IEObjectDescription,T> indexer) {
ArrayList<IEObjectDescription> list = Lists.newArrayList(descriptions);
LinkedHashMultimap<T, IEObjectDescription> multimap = LinkedHashMultimap.create(list.size(),1);
for (IEObjectDescription desc : list) {
multimap.put(indexer.apply(desc), desc);
return multimap;
public static Multimap<QualifiedName,IEObjectDescription> index(Iterable<IEObjectDescription> descriptions) {
return index(descriptions, new Function<IEObjectDescription, QualifiedName>() {
public QualifiedName apply(IEObjectDescription from) {
return from.getName().toLowerCase();
public static Iterable<IEObjectDescription> filterDuplicates(Iterable<IEObjectDescription> filtered) {
Map<QualifiedName, IEObjectDescription> result = Maps.newLinkedHashMap();
for (IEObjectDescription e : filtered) {
QualifiedName qualifiedName = e.getName();
if (result.containsKey(qualifiedName)) {
result.put(qualifiedName, null);
} else {
result.put(qualifiedName, e);
return Iterables.filter(result.values(), Predicates.notNull());
Re: Referenced DSL-Files are not recognized on clean [message #1838691 is a reply to message #1838569] |
Wed, 03 March 2021 16:37 |
After long debugging I found out, that Xtext/Eclipse did not resolve proxy-objects correctly. After resolving them by hand, everything worked.
Here is the altered code:
@Check
def checkNumberOfProcessArguments(Process p) {
var numberArgsGiven = 0
var numberArgsDefMin = 0
var numberArgsDefMax = 0
if (p.parameter !== null) {
numberArgsGiven = p.parameter.size;
if (p.process !== null) {
if (p.process.eIsProxy) { // resolve proxy
var XtextResourceSet rs = new XtextResourceSet();
rs.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, java.lang.Boolean.TRUE);
p.process = p.process.resolve(rs) as ProcessDefinition
numberArgsDefMax = p.process.parameter.size;
numberArgsDefMin = p.process.parameter.filter[defaultValue === null].size;
/* add all out-parameters also */
if (p.process.result !== null) {
numberArgsDefMax += p.process.result.results.size;
numberArgsDefMin += p.process.result.results.size;
if ((numberArgsGiven > numberArgsDefMax) || (numberArgsGiven < numberArgsDefMin)) {
if (numberArgsDefMax != numberArgsDefMin) {
error(
"Die Anzahl der Parameter muss zwischen " + numberArgsDefMin + " und " + numberArgsDefMax + " sein",
p, TabsPackage.eINSTANCE.process_Parameter, NUMBER_ARGS)
} else {
error("Die Anzahl der Parameter muss " + numberArgsDefMin + " sein",
FUDForum. Page generated in 0.03123 seconds
