Home » Archived » BIRT » Problem Deploying Birt Viewer from latest Runtime(Missing org.eclipse.birt.report.listener.ViewerServletContextListener)
Problem Deploying Birt Viewer from latest Runtime [message #1838392] Tue, 23 February 2021 23:30 Go to next message
I deployed Tomcat 10 and then copied the contents of the webviewerexample folder to webapps like the instruction state. When I try to start Birt I receive the following error:
24-Feb-2021 10:45:54.811 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class [org.eclipse.birt.report.listener.ViewerServletContextListener]
java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1016)
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:151)
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2433)
at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:864)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1333)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1187)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:540)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:521)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:151)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4589)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5126)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:706)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1093)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1810)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1013)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:428)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1520)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:936)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:843)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:434)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
at org.apache.catalina.startup.Catalina.start(Catalina.java:795)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:342)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:473)
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1364)
... 51 more
24-Feb-2021 10:45:54.867 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class [org.eclipse.birt.report.listener.ViewerHttpSessionListener]
java.lang.NoClassDefFoundError: javax/servlet/http/HttpSessionListener
Caused by: java.lang.ClassNotFoundException: javax.servlet.http.HttpSessionListener
... 51 more
24-Feb-2021 10:45:54.867 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Skipped installing application listeners due to previous error(s)
When I go looking for the file it doesnt exist anywhere in the download zip. Any ideas? Thanks.
[Updated on: Wed, 24 February 2021 11:21] by Moderator
Re: Problem Deploying Birt Viewer from latest Runtime [message #1838472 is a reply to message #1838392] Thu, 25 February 2021 11:25 Go to previous messageGo to next message
Since I have seen no replies I will update when I have learned. YOU CAN'T RUN TOMCAT 10 with Birt runtime 4.8. It has to be either 9 or 8. For some reasons there must be some classes that were removed in Tomcat 10. Hopefully this helps someone, unless no one is running Birt Runtime.
Re: Problem Deploying Birt Viewer from latest Runtime [message #1841971 is a reply to message #1838472] Fri, 04 June 2021 14:29 Go to previous message
Hi, just wanted to let you know that this was useful information to me.
It's still valid!
Looks like they are prepping for a new BiRT release, so maybe this will work with Tomcat 10 soon.
Cheers!
Previous Topic:Avoid word cutting by automatic line break
Next Topic:create multiple sheets in Excel report
Current Time: Mon Mar 24 20:10:37 EDT 2025
Powered by FUDForum. Page generated in 0.14850 seconds
