Home » Modeling » TMF (Xtext) » Validator Testing with JUnit 5
Validator Testing with JUnit 5 [message #1838277] Sat, 20 February 2021 08:21 Go to next message
Oli Ana is currently offline Oli AnaFriend
Hi all,
I can't figure out how to test the custom validator developed for my grammar using Junit 5. At runtime the error is triggered, but when testing everything seems ok, no error is fired.
I've read the documentation (web and book), looked carefully at every example in eclipse, but I didn't have any success.
This is a simplified version of the code.
The grammar:
grammar org.xtext.example.mydsl.Mydsl with org.eclipse.xtext.common.Terminals
generate mydsl ...
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID '!';
The custom validator:
package org.xtext.example.mydsl.validation;
import org.eclipse.xtext.validation.Check;
import org.xtext.example.mydsl.mydsl.MydslPackage;
import org.xtext.example.mydsl.mydsl.Greeting;
public class MydslValidator extends AbstractMydslValidator {
	public static final String INVALID_NAME = "invalidName";
	@Check
	public void checkGreetingStartsWithCapital(Greeting greeting) {
		if (!Character.isUpperCase(greeting.getName().charAt(0))) {
			warning("Name should start with a capital",
					MydslPackage.Literals.GREETING__NAME,
					INVALID_NAME);
and the tests
package org.xtext.example.mydsl.tests
import com.google.inject.Inject
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.extensions.InjectionExtension
import org.eclipse.xtext.testing.util.ParseHelper
import org.eclipse.xtext.testing.validation.ValidationTestHelper
import org.junit.jupiter.api.Test
import org.junit.jupiter.api.^extension.ExtendWith
import org.xtext.example.mydsl.mydsl.Model
import org.xtext.example.mydsl.validation.MydslValidator
@ExtendWith(InjectionExtension)
@InjectWith(MydslInjectorProvider)
class MydslValidationTest {
	@Inject extension
	ParseHelper<Model>
	@Inject extension ValidationTestHelper
	@Test
	def void greetingStartsWithCapitalTest(){
		val result = '''
			Hello xtext!
		'''.parse
		result.assertWarning(MydslPackage.Literals.GREETING, "Name should start with a capital", MydslValidator.INVALID_NAME)
The result:
Expected WARNING 'Name should start with a capital' on Greeting at [-1:-1] but got
if I replace
with
result.assertNoErrors()
The test succeeds.
If I introduce any syntax error in the model to be tested, an error is fired.
I guess my validator isn't taken into account while testing. What am I missing?
Any help would be appreciated.
Thanks in advance.
Re: Validator Testing with JUnit 5 [message #1838292 is a reply to message #1838277] Sat, 20 February 2021 17:09 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
this is a regression in Xtext 2.24.
if you use 2.25 M1 or M2 it should be fixed
https://github.com/eclipse/xtext-core/issues/1648
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Validator Testing with JUnit 5 [message #1838313 is a reply to message #1838292] Mon, 22 February 2021 08:35 Go to previous messageGo to next message
Thanks for the quick response.
However, I can't manage to install either of the milestones...
An error occurred while collecting items to be installed
session context was:(profile=C__Users_xxx_eclipse_dsl-2020-12_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.xtend.core,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.doc,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.examples,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.ide,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.ide.common,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.lib,2.25.0.v20210203-0750.
Artifact not found: osgi.bundle,org.eclipse.xtend.lib.macro,2.25.0.v20210203-0750.
Artifact not found: osgi.bundle,org.eclipse.xtend.m2e,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtend.standalone,2.25.0.v20210203-0838.
Artifact not found: osgi.bundle,org.eclipse.xtext,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.activities,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.builder,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.builder.standalone,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.buildship,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.edit,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.shared,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.shared.jdt38,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.doc,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ecore,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.generator,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.ide,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.java,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.junit4,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.logging,1.2.15.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.m2e,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase.ide,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.smap,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.testing,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codemining,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates.ide,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.ecore,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.shared,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.testing,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.util,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ide,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.junit,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.lib,2.25.0.v20210203-0750.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.testing,2.25.0.v20210203-0759.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ui.testing,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.generator,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ide,2.25.0.v20210203-0753.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui.examples,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui.graph,2.25.0.v20210203-0811.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.wizard,2.25.0.v20210203-0753.
[Updated on: Mon, 22 February 2021 10:02]
Report message to a moderator
Re: Validator Testing with JUnit 5 [message #1838317 is a reply to message #1838313] Mon, 22 February 2021 10:01 Go to previous messageGo to next message
please note: we are publishing a new milestone right now so the webservers might not deliver complete data right now.
can you try this repo: http://www.eclipse.org/modeling/download.php?file=/modeling/tmf/xtext/downloads/drops/2.25.0/S202102220934/tmf-xtext-Update-2.25.0.M3.zip
Re: Validator Testing with JUnit 5 [message #1838318 is a reply to message #1838317] Mon, 22 February 2021 10:02 Go to previous messageGo to next message
you may also comment
https://bugs.eclipse.org/bugs/show_bug.cgi?id=571058
Re: Validator Testing with JUnit 5 [message #1838320 is a reply to message #1838318] Mon, 22 February 2021 10:39 Go to previous messageGo to next message
@Oli Ana do you have any malware detection (e.g. traps) on your machine? which os do you use?
Re: Validator Testing with JUnit 5 [message #1838321 is a reply to message #1838320] Mon, 22 February 2021 11:05 Go to previous message
I succeeded installing M2 by changing the eclipse.ini file to use C:\Program Files\AdoptOpenJDK\jdk-11.0.10.9-hotspot\bin instead of
C:/Users/xxx/.p2/pool/plugins/org.eclipse.justj.openjdk.hotspot.jre.full.win32.x86_64_15.0.1.v20201027-0507/jre/bin as stated here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=571058
My validator is loaded for testing now.
Thank you very much for the responses.
Previous Topic:Rename fails if cursor is behind identifier
Next Topic:Scoping / Linking
Current Time: Fri Apr 23 03:20:52 GMT 2021
Powered by FUDForum. Page generated in 0.02592 seconds
