Home » Eclipse Projects » Eclipse Scout » Error while importing Scout Demo Contact App(importing fails because of a github.com login problem)
Error while importing Scout Demo Contact App [message #1838206] Thu, 18 February 2021 15:16 Go to next message
J D is currently offline J DFriend
Member
Hello there,
I am following the Eclipse Scout Beginners Guide and I have tried twice unsuccessfully to import the Eclipse Scout Demo App in order to complete Section 4.5.1 in the Beginners Guide.
I need to copy the following highlighted classes (see image below) from the imported Scout Demo App:
index.php/fa/40010/0/
However, the Demo App import fails because of the following error:
ERROR: org.eclipse.oomph.setup.core code=0 org.eclipse.jgit.api.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Cannot log in at github.com:22
Exception log in full
Executing manual tasks
OpenJDK Runtime Environment 11.0.9+11
Product self.product.version
Workspace C:\Users\Jide\eclipse-scout-workspace
Project org.eclipse.scout.scout.docs.features/version/11.0.3
Bundle org.eclipse.oomph.setup 1.18.0.v20201230-0937, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.core 1.19.0.v20210111-1121, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.git 1.18.0.v20200624-1156, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.jdt 1.17.0.v20201231-0810, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.maven 1.14.0.v20200624-1156, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.p2 1.16.0.v20200814-1205, build=4919, branch=f78238ba11ce04fb6bb89f0cb98f4dd759377d1d
Bundle org.eclipse.oomph.setup.pde 1.12.0.v20200624-1156, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.projects 1.13.0.v20200624-1156, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.targlets 1.13.0.v20200624-1156, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Bundle org.eclipse.oomph.setup.workingsets 1.13.0.v20200815-0620, build=4985, branch=6a3a5fc19e837c1408149bd66af770f2cb5a00c0
Performing Text Modify configuration:/config.ini
Modifying file:/C:/Users/Jide/Portable/eclipse_scout/configuration/config.ini
Performing JRE for JavaSE-1.8 = C:\Program Files\AdoptOpenJDK\jdk-11.0.9.11-hotspot
Creating JRE for JavaSE-1.8 with location C:\Program Files\AdoptOpenJDK\jdk-11.0.9.11-hotspot
Setting the default execution environment to JRE for JavaSE-1.8
Performing Git Clone git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git  (features/version/11.0.3)
Cloning Git repo git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git to C:\Users\Jide\Portable\git\org.eclipse.scout.docs
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Cannot log in at github.com:22
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:989)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3851)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3794)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:5160)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2317)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:5154)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:5152)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3785)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3760)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3638)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:595)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:722)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.jgit.api.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Cannot log in at github.com:22
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:222)
  at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:302)
  at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:178)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:1051)
  at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:888)
  ... 1 more
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:BSI-Business-Systems-Integration-AG/org.eclipse.scout.docs.git: Cannot log in at github.com:22
  at org.eclipse.jgit.transport.sshd.SshdSession.connect(SshdSession.java:171)
  at org.eclipse.jgit.transport.sshd.SshdSession.connect(SshdSession.java:96)
  at org.eclipse.jgit.transport.sshd.SshdSessionFactory.getSession(SshdSessionFactory.java:231)
  at org.eclipse.jgit.transport.sshd.SshdSessionFactory.getSession(SshdSessionFactory.java:1)
  at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:107)
  at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:254)
  at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:144)
  at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:105)
  at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:91)
  at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1260)
  at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:211)
  ... 2 more
Caused by: org.apache.sshd.common.SshException: No more authentication methods available
  at org.apache.sshd.client.session.ClientUserAuthService.tryNext(ClientUserAuthService.java:333)
  at org.apache.sshd.client.session.ClientUserAuthService.processUserAuth(ClientUserAuthService.java:266)
  at org.apache.sshd.client.session.ClientUserAuthService.process(ClientUserAuthService.java:212)
  at org.apache.sshd.common.session.helpers.AbstractSession.doHandleMessage(AbstractSession.java:466)
  at org.apache.sshd.common.session.helpers.AbstractSession.handleMessage(AbstractSession.java:392)
  at org.apache.sshd.common.session.helpers.AbstractSession.decode(AbstractSession.java:1304)
  at org.apache.sshd.common.session.helpers.AbstractSession.messageReceived(AbstractSession.java:348)
  at org.eclipse.jgit.internal.transport.sshd.JGitClientSession.messageReceived(JGitClientSession.java:330)
  at org.apache.sshd.common.session.helpers.AbstractSessionIoHandler.messageReceived(AbstractSessionIoHandler.java:63)
  at org.apache.sshd.common.io.nio2.Nio2Session.handleReadCycleCompletion(Nio2Session.java:368)
  at org.apache.sshd.common.io.nio2.Nio2Session$1.onCompleted(Nio2Session.java:346)
  at org.apache.sshd.common.io.nio2.Nio2Session$1.onCompleted(Nio2Session.java:343)
  at org.apache.sshd.common.io.nio2.Nio2CompletionHandler.lambda$completed$0(Nio2CompletionHandler.java:38)
  at java.base/java.security.AccessController.doPrivileged(Native Method)
  at org.apache.sshd.common.io.nio2.Nio2CompletionHandler.completed(Nio2CompletionHandler.java:37)
  at java.base/sun.nio.ch.Invoker.invokeUnchecked(Invoker.java:127)
  at java.base/sun.nio.ch.Invoker$2.run(Invoker.java:219)
  at java.base/sun.nio.ch.AsynchronousChannelGroupImpl$1.run(AsynchronousChannelGroupImpl.java:112)
  ... 3 more
  ... 1 more
  ... 2 more
  ... 3 more
Took 16 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
What do I do now? Can anybody please send me a link to where I can download the classes directly?
Thanks a lot,
JD
[Updated on: Thu, 18 February 2021 15:17]
Report message to a moderator
Re: Error while importing Scout Demo Contact App [message #1838208 is a reply to message #1838206] Thu, 18 February 2021 15:24 Go to previous messageGo to next message
Member
I just found this
https://github.com/bsi-software/org.eclipse.scout.docs/tree/releases/10.0/code/contacts/org.eclipse.scout.contacts.server/src/main/java/org/eclipse/scout/contacts/server/sql
Are the classes here identical to the Contacts Demo?
JD
Re: Error while importing Scout Demo Contact App [message #1838209 is a reply to message #1838206] Thu, 18 February 2021 15:27 Go to previous messageGo to next message
Arthur van Dorp is currently offline Arthur van DorpFriend
Member
When importing via Oomph, did you provide your GitHub credentials? Alternatively you can simply import it anonymously: In the Eclipse Importer wizard, choose Oomph/Scout/Scout Demo App, on the next page (called "Variables") in the lower left click on "Show all variables", on the now visible forth line called "Scout Demo App GitHub repository" choose "HTTPS (read-only, anonymous)".
Edit: That should read HTTPS, not HTTP.
[Updated on: Thu, 18 February 2021 15:34]
Re: Error while importing Scout Demo Contact App [message #1838210 is a reply to message #1838208] Thu, 18 February 2021 15:31 Go to previous messageGo to next message
Member
Yes, that would be the same classes. Make sure you choose the right version. If you're e.g. on 10.0.42, then choose the branch features/version/10.0.42 from the branch/tag dropdown menu.
[Updated on: Thu, 18 February 2021 16:05]
Re: Error while importing Scout Demo Contact App [message #1838399 is a reply to message #1838206] Wed, 24 February 2021 08:18 Go to previous messageGo to next message
Mark Novem Grisola is currently offline Mark Novem GrisolaFriend
Based on the error logs, it try to get some resources at github thru 22 port. I assumed you follow the guide carefully. The other factor that could cause this problem is your network. If you're under a managed network and it has a firewall, then check if that port(22) is not blocked by firewall to access outside(WAN) network.
Re: Error while importing Scout Demo Contact App [message #1838512 is a reply to message #1838399] Fri, 26 February 2021 19:12 Go to previous message
Member
Thanks a lot for your responses. Fetching the data anonymously worked for me.
JD
Previous Topic:Adding heatmap example to my project leads to empty page
Next Topic:Eclipse Scout Hello World tutorial issue
Current Time: Sat Apr 20 23:19:46 GMT 2024
Powered by FUDForum. Page generated in 0.03316 seconds
