Home » Modeling » TMF (Xtext) » Cannot set map object to context of XBaseInterpreter
Cannot set map object to context of XBaseInterpreter [message #1837868] Tue, 09 February 2021 07:07 Go to next message
Udo Walker is currently offline Udo WalkerFriend
Member
I subclassed XbaseInterpreter and in my method I call evaluate(..) of the super class.
If I add an object of type java.util.List to the EvaluationContext everything works find when I reference it in my XExpression.
When I add an object of type java.util.Map I get the error message
java.lang.IllegalArgumentException: Segment cannot be null
	at org.eclipse.xtext.naming.QualifiedName.create(QualifiedName.java:240)
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1099)
How could I fix this?
Re: Cannot set map object to context of XBaseInterpreter [message #1837871 is a reply to message #1837868] Tue, 09 February 2021 10:20 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
which Xtext version do you use?
did you debug what is actually null?
can you provide a reproducing unit test/java main e.g. with domain model example
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:defect xtext version?
Next Topic:EMF - adding new model objects programmatically
Current Time: Thu Apr 15 17:27:56 GMT 2021
Powered by FUDForum. Page generated in 0.02292 seconds
