Home » Eclipse Projects » Eclipse Jersey » IPv6 support(Does jersey library support IPv6 addresses in the URL?)
IPv6 support [message #1837728] Thu, 04 February 2021 19:26 Go to next message
Sandeep D is currently offline Sandeep DFriend
We are using Jersey library to communicate using RESTful APIs. We use resolveTemplate API to resolve the URL template with actual IP address. Something like this: private static final String API_URL_TMPL = "https://{nodeIp}:9000/api/v2/abc/"; private static final String VAR_NODE_IP = "nodeIp";
new JerseyWebTarget(API_URL_TMPL, jerseyClient).resolveTemplate(VAR_NODE_IP, nodeIp);
jerseyClient is created previously. nodeIp value being passed is [6001::f816:3eff:fe87:c1a8]
We are hitting this issue: javax.ws.rs.ProcessingException: java.net.UnknownHostException: %5B6001%3A%3Af816%3A3eff%3Afe87%3Ac1a8%5D
Does jersey even support IPv6 ? How to overcome this?
Thanks !
Re: IPv6 support [message #1838303 is a reply to message #1837728] Sun, 21 February 2021 22:17 Go to previous message
No reply? No one knows?
Previous Topic:Object instantiation problem
Next Topic:Message Body Writer for Moxy List
Current Time: Tue Apr 16 15:25:57 GMT 2024
Powered by FUDForum. Page generated in 0.16133 seconds
