Home » Modeling » TMF (Xtext) » defect xtext version?(central repository seems to have invalid maven-metadata.xml)
defect xtext version? [message #1837692] Thu, 04 February 2021 09:41 Go to next message
Ralf Sieger is currently offline Ralf SiegerFriend
not sure if this is the correct forum.
But it is xtext related so I give it a try...
Since yesterday afternoon our maven build fails.
The reason is an "invalid" maven-metadata.xml
https://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.testing/
Same problem:
https://repo1.maven.org/maven2/org/eclipse/xtext/org.eclipse.xtext.util/
This file contains only one version: 2.25.0.M2
Instead of multiple, old versions, too.
So as the version our build needs (2.9.2) is not included our build fails.
Does anybody know if this a problem on our side or is the version info defect...?
thanks in advance
Ralf
Re: defect xtext version? [message #1837693 is a reply to message #1837692] Thu, 04 February 2021 09:44 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
maybe some temporary outage? here is what i see
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: defect xtext version? [message #1837694 is a reply to message #1837693] Thu, 04 February 2021 09:45 Go to previous messageGo to next message
ok the xml is broken
but i dont know how this is created
<metadata>
<groupId>org.eclipse.xtext</groupId>
<artifactId>org.eclipse.xtext.util</artifactId>
<versioning>
<latest>2.25.0.M2</latest>
<release>2.25.0.M2</release>
<versions>
<version>2.25.0.M2</version>
</versions>
<lastUpdated>20210203143224</lastUpdated>
</versioning>
</metadata>
Re: defect xtext version? [message #1837695 is a reply to message #1837694] Thu, 04 February 2021 09:47 Go to previous messageGo to next message
https://issues.sonatype.org/browse/OSSRH-63268
Re: defect xtext version? [message #1837696 is a reply to message #1837695] Thu, 04 February 2021 09:54 Go to previous messageGo to next message
Hi Christian,
thanks for the fast reply.
At least we now know the cause.
regards,
Ralf
Re: defect xtext version? [message #1837719 is a reply to message #1837696] Thu, 04 February 2021 16:52 Go to previous messageGo to next message
Ralf Mollik is currently offline Ralf MollikFriend
is there any chance to get it fixed? Our CI is no longer working due to this defect.
Thank you in advance.
Ralf
Re: defect xtext version? [message #1837720 is a reply to message #1837719] Thu, 04 February 2021 17:08 Go to previous messageGo to next message
Do you use maven or Tycho or gradle
Re: defect xtext version? [message #1837721 is a reply to message #1837720] Thu, 04 February 2021 17:09 Go to previous messageGo to next message
And we are waiting for feedback from sonatype what todo
Re: defect xtext version? [message #1837725 is a reply to message #1837721] Thu, 04 February 2021 18:43 Go to previous messageGo to next message
see also https://github.com/eclipse/xtext-xtend/issues/1174
Re: defect xtext version? [message #1837740 is a reply to message #1837725] Fri, 05 February 2021 06:54 Go to previous messageGo to next message
looks like the problem was solved in the meantime on sonatype side. please retest
Re: defect xtext version? [message #1837743 is a reply to message #1837740] Fri, 05 February 2021 07:50 Go to previous message
we're using maven.
it does work again - thank you very much!
Previous Topic:Use XText in batch mode
Next Topic:Cannot set map object to context of XBaseInterpreter
Current Time: Fri Jun 02 15:39:54 GMT 2023
Powered by FUDForum. Page generated in 0.02422 seconds
