Home » Modeling » TMF (Xtext) » Using FQN rule in reference rules does not work as expexcted.(Qualified name does not resolve)
Using FQN rule in reference rules does not work as expexcted. [message #1837082] Thu, 21 January 2021 17:54 Go to next message
Olaf Bigalk is currently offline Olaf BigalkFriend
I have the following parts in my grammar:
DynamicText:
	name=ID ":=" feature=[ecore::EStructuralFeature|QN] ("with" function=ID)
terminal QN:
	ID ('.' ID)+
the generated editor depicts that "DynamicText" could not be resolved.
var xxx := DynamicText.feature
I exspected " DynamicText.feature" gets parsed together as QN and then be compared to the scope provided here.
What is wrong ?
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837083 is a reply to message #1837082] Thu, 21 January 2021 18:42 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
afaik estructural features are not in the index so it wont work with default scoping.
maybe you can try an eclass with QN + a separate reference for the feature.
or you do a reference to an epackage and do scoping for the qualified features manually.
also see open model element dialog
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837089 is a reply to message #1837083] Thu, 21 January 2021 22:19 Go to previous messageGo to next message
Sorry, I didn't mentioned I have a custom ScopeProvider for this feature and that delivers exactly what you see "DynamicText.feature"
That is why I am wondering about this behavior
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837096 is a reply to message #1837089] Fri, 22 January 2021 04:48 Go to previous messageGo to next message
Then please give more details
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837151 is a reply to message #1837096] Fri, 22 January 2021 20:06 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 21 January 2021 23:48
First Thanks for the answer.
Would you be so kind to specify which details you need to analyse the problem?
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837156 is a reply to message #1837151] Fri, 22 January 2021 21:23 Go to previous messageGo to next message
The problem has disappeared some how.
Thank you for taking time for me.
Re: Using FQN rule in reference rules does not work as expexcted. [message #1837163 is a reply to message #1837156] Sat, 23 January 2021 05:44 Go to previous message
I would have expected: this is how my scope provider looks like
(Code snippet oder pseudo code here)
Previous Topic:Import of Xtext Grammar Model
Next Topic:[Formatter2] append newLine + spaces
Current Time: Sun Apr 18 09:43:28 GMT 2021
Powered by FUDForum. Page generated in 0.02842 seconds
