Home » Modeling » TMF (Xtext) » DeclarativeScopeProvider as delegate(How to integrate my own DeclarativeScopeProvider into the generated stub)
DeclarativeScopeProvider as delegate [message #1837072] Thu, 21 January 2021 15:26 Go to next message
Olaf Bigalk is currently offline Olaf BigalkFriend
I have implemented my own ScopeProvider for my grammar.
But somehow I am not able to integrate it streamlining with the stubs generated be Xtext
The stub is GeneratorModelScopeProvider(package omitted)
it is an AbstractGeneratorModelScopeProvider which in turn is an
DelegatingScopeProvider.
During debugging I recognized that the ScopeProvider is instantiated over and over again. Which surprise me. because I thought this instance could be reused for the whole runtime.
I suffered some NullPointerExeptions because one delegate in the generated stub does not get set as it should be.
I guess I only need to Guice annotate my ScopeProvider in the right way and the problem is solved.
Re: DeclarativeScopeProvider as delegate [message #1837073 is a reply to message #1837072] Thu, 21 January 2021 15:28 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
which delegate do you mean and what are you doing
the normal delegating scopeprovider is bound by
public void configureIScopeProviderDelegate(Binder binder) {
binder.bind(IScopeProvider.class).annotatedWith(Names.named(AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(ImportedNamespaceAwareLocalScopeProvider.class);
in AbstractMyDslRuntimeModule
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Thu, 21 January 2021 15:29]
Report message to a moderator
Previous Topic:Import MyDslStandaloneSetup does not resolve
Next Topic:Import of Xtext Grammar Model
Current Time: Fri Jan 21 00:20:22 GMT 2022
Powered by FUDForum. Page generated in 0.02417 seconds
