Home » Newcomers » Newcomers » Java Build Path tab not appearing
Java Build Path tab not appearing [message #1836997] Wed, 20 January 2021 18:50 Go to next message
Gabriel Lemus is currently offline Gabriel LemusFriend
I installed eclipse on my computer using a guide from a tutorial (Setting up the Workspace - Minecraft Forge 1.16.4 Modding Tutorial) as well as the JDK from the previous video in the playlist. The tutorial requires that I be able to access the Java Build Path tab but it is not there. The attached image shows what my properties window looks like. If anyone could tell me something the creator neglected to mention in the video or what the problem may be it would be greatly appreciated.
  • Attachment: Capture.PNG
    (Size: 45.42KB, Downloaded 44 times)
Re: Java Build Path tab not appearing [message #1836998 is a reply to message #1836997] Wed, 20 January 2021 19:19 Go to previous messageGo to next message
I figured it out
Re: Java Build Path tab not appearing [message #1837824 is a reply to message #1836998] Mon, 08 February 2021 10:54 Go to previous messageGo to next message
Stachey exe is currently offline Stachey exeFriend
I am having the same problem how did you fix it ?
Re: Java Build Path tab not appearing [message #1837849 is a reply to message #1837824] Mon, 08 February 2021 15:19 Go to previous message
Your project is probably not a Java project. Perhaps this will be useful:
https://www.eclipse.org/forums/index.php/mv/msg/1106846/1837736/#msg_1837736
Ed Merks
Previous Topic:GLSP graphical editor
Next Topic:Eclipse Syntax Checking Settings
Current Time: Mon Sep 20 05:49:42 GMT 2021
Powered by FUDForum. Page generated in 0.02636 seconds
