Home » Newcomers » Newcomers » Error message Cant find class or load main
Error message Cant find class or load main [message #1836677] Tue, 12 January 2021 00:26 Go to next message
Travis Tzer is currently offline Travis TzerFriend
Hi I am using Eclipse 20-12 to try to write Java code. Via Java SE Develop Kit 11.0.9. in Windows 10.
I am getting this error
Error: Could not find or load main class MySweetProgram
Caused by: java.lang.ClassNotFoundException: MySweetProgram
public class MySweetProgram {
System.out.println("Hello World!");
and I not including something in the code or possibly compiler was installed wrong ? Thanks in advance
Re: Error message Cant find class or load main [message #1836679 is a reply to message #1836677] Tue, 12 January 2021 04:39 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Have you tried putting your class somewhere other than the Default Package (i.e. by creating a New Package and dragging the class into it)? And does this message happen when using Run As->Java Application from inside Eclipse with the class selected?
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Begin Select and End Select key bindings
Next Topic:Eclipse RCP Application (using p2 repo) Build automation using Ant
Current Time: Thu Mar 04 00:46:59 GMT 2021
Powered by FUDForum. Page generated in 0.03234 seconds
