Home » Modeling » TMF (Xtext) » How to use a custom IAllContainersState
How to use a custom IAllContainersState [message #1836567] Thu, 07 January 2021 16:01 Go to next message
Yannick DAVELUY is currently offline Yannick DAVELUYFriend
In MyDslUIModule I added the following override
	public Provider<IAllContainersState> provideIAllContainersState() {
		return Access.<IAllContainersState>contributedProvider(MyDslProjectsState.class);
The MyDslProjectsState class is declared in the ui Plugin.
I have the following guice error when I launch my application :
1) Error injecting method, java.lang.IllegalStateException: Missing contribution for type: mydsl.ui.containers.MyDslProjectsState
  at org.eclipse.xtext.ui.shared.Access$InternalProviderForContribution.inject(Unknown Source)
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:76)
I tried to use the org.eclipse.xtext.ui.shared.sharedStateContributingModule but I don't understand how it works.
Any Hints ?
Yannick
Re: How to use a custom IAllContainersState [message #1836569 is a reply to message #1836567] Thu, 07 January 2021 16:09 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Simply create a new class that inherits from guices Module interface or one of the subclasses and register it via the extension point
Still wonder what problem zu want to solve
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Thu, 07 January 2021 16:10]
Report message to a moderator
Re: How to use a custom IAllContainersState [message #1836570 is a reply to message #1836569] Thu, 07 January 2021 16:27 Go to previous messageGo to next message
Ok thanks but I already tried this without success.
What I need is to store my dsl files in a plugin projects with the pde nature but without the java nature. Then I would like to get the visibles handles from the project Manifest.
Yannick
Re: How to use a custom IAllContainersState [message #1836571 is a reply to message #1836570] Thu, 07 January 2021 16:37 Go to previous messageGo to next message
Please provide more details what you exactly did
Re: How to use a custom IAllContainersState [message #1836572 is a reply to message #1836571] Thu, 07 January 2021 18:26 Go to previous messageGo to next message
I finally solved the problem, my configure function in MyDslSharedModule was empty...
So in myDsl UI project I created :
The module:
public class MyDslSharedModule extends AbstractModule {
	protected void configure() {
		bind(MyDslProjectsState.class);
		bind(MyDslProjectsStateHelper.class);
In the MyDslUiModule
public class MyDslUiModuleextends AbstractMyDslUiModule {
The MyDslProjectState:
public class MyDslProjectsState extends WorkspaceProjectsState {
	@Inject
	private MyDslProjectsStateHelper projectsHelper;
	protected String doInitHandle(URI uri) {
		return projectsHelper.initHandle(uri);
	protected Collection<URI> doInitContainedURIs(String containerHandle) {
		return projectsHelper.initContainedURIs(containerHandle);
	protected List<String> doInitVisibleHandles(String handle) {
		return projectsHelper.initVisibleHandles(handle);
And the Helper
public class MyDslProjectsStateHelper extends WorkspaceProjectsStateHelper {
And the plugin.xml
   <extension
         point="org.eclipse.xtext.ui.shared.sharedStateContributingModule">
      <module
            class="mydsl.MyDslSharedModule">
      </module>
   </extension>
I have to implements the MyDslProjectsStateHelper to retrieve visible handlers from the manifest
[Updated on: Thu, 07 January 2021 18:26]
Re: How to use a custom IAllContainersState [message #1836577 is a reply to message #1836572] Thu, 07 January 2021 21:27 Go to previous messageGo to next message
The existing WorkspaceProjectsStateHelper collect the referenced projects and it already include the projects from the Manifest via org.eclipse.pde.internal.core.DynamicPluginProjectReferences.
The problem is that when the Manifest is updated, the index is not rebuilt.
I overrode the WorkspaceProjectsState.isAffectingContainerState like this :
	private final Path manifestPath = new Path("META-INF/MANIFEST.MF");
	protected boolean isAffectingContainerState(IResourceDelta delta) {
		if (manifestPath.equals(delta.getProjectRelativePath())) {
			delta.getResource().getProject().clearCachedDynamicReferences();
			return true;
		return super.isAffectingContainerState(delta);
Then I have to manually trigger a project clean in order to rebuild the dsl files inside the project.
How to trigger a clean/rebuild of the xtext index ?
Yannick
Re: How to use a custom IAllContainersState [message #1836581 is a reply to message #1836577] Fri, 08 January 2021 06:40 Go to previous messageGo to next message
the manifest change should lead to a classpath change which should lead to a rebuild.
you may start debug around BuilderDeltaConverter, ProjectClasspathChangeListener, JavaProjectClasspathChangeAnalyzer
otherwise this may be a bug in PDE !? if clearCachedDynamicReferences needs to be called manually
and or Xtext if we dont treat the classpath change somewhere else
[Updated on: Fri, 08 January 2021 06:48]
Re: How to use a custom IAllContainersState [message #1836582 is a reply to message #1836581] Fri, 08 January 2021 07:08 Go to previous messageGo to next message
Hi Christian,
In my case I don't have a classpath because I don't have the java nature (just PDE and manifestBuiler).
I have to call clearCachedDynamicReferences manually and then to forget the last built state to make it works.
			final XtextBuilder builder = BuildManagerAccess.findBuilder(delta.getResource().getProject());
			if (builder != null) {
				builder.forgetLastBuiltState();
I think that there is a bug somewhere but I couln't say if it is on PDE or Xtext side.
Thanks for your help
Re: How to use a custom IAllContainersState [message #1836590 is a reply to message #1836582] Fri, 08 January 2021 09:03 Go to previous message
can you please create an issue at https://github.com/eclipse/xtext-eclipse/
with details on your project setup and changes you do
Previous Topic:Type library not found with StadaloneSetup
Next Topic:Xtend Maven issues after upgrading to Java 9
Current Time: Sat Jun 19 23:13:46 GMT 2021
Powered by FUDForum. Page generated in 0.02523 seconds
