Home » Eclipse Projects » e(fx)clipse » Error when trying to inspect e4 apps with Scenic View
Error when trying to inspect e4 apps with Scenic View [message #1836526] Wed, 06 January 2021 21:54 Go to next message
Stephane  fournier is currently offline Stephane fournierFriend
Happy New Year e(fx)clipse community :-)
I have an e4 rcp app based on efx running with AdoptOpenJDK 15 + OpenJFX 15.
In my product file I have this to make it run smoothly:
-Dosgi.framework.extensions=org.eclipse.fx.osgi
-Defxclipse.java-modules.dir=/path/to/javafx-sdk-15.0.1/lib
In parallel, I run ScenicView (v11.0.2) from a terminal with this command:
java --module-path /path/to/javafx-sdk-15.0.1/lib --add-modules javafx.controls,javafx.web,javafx.fxml,javafx.swing -jar scenicview.jar
When ScenicView detects my e4 rcp app, in the traces of my app I got some ClassNotFoundException against JavaFX classes (see below ***).
I tried to add, as default VM args, --module-path and --add-modules directives, but it still fails with other errors and the e4 app is no longer launching.
Does anyone have an idea or experience with e4 RCP with JFX11 and Scenic View please ?
Exception in thread "Attach Listener" java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at java.instrument/sun.instrument.InstrumentationImpl.loadClassAndStartAgent(InstrumentationImpl.java:513)
at java.instrument/sun.instrument.InstrumentationImpl.loadClassAndCallAgentmain(InstrumentationImpl.java:535)
Caused by: java.lang.NoClassDefFoundError: javafx/collections/ListChangeListener
at org.fxconnector.remote.RuntimeAttach.init(RuntimeAttach.java:85)
at org.fxconnector.remote.RuntimeAttach.agentmain(RuntimeAttach.java:58)
... 6 more
Caused by: java.lang.ClassNotFoundException: javafx.collections.ListChangeListener
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:606)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:168)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 8 more
Agent failed to start!
Re: Error when trying to inspect e4 apps with Scenic View [message #1836743 is a reply to message #1836526] Wed, 13 January 2021 09:40 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
well the problem is that ScenicView is trying to load stuff through the Systemclassloader which can not work as those are loaded in an extra JPMS-Layer and each layer has to have a distinct classloader. So you have 2 options:
* Use something like ZuluFX which includes JavaFX as part of the System-Modules
* Do not launch ScenicView as an external application but wrap it as an OSGi-Module and create an instance as part of your OSGi-Application
Re: Error when trying to inspect e4 apps with Scenic View [message #1836783 is a reply to message #1836743] Wed, 13 January 2021 19:56 Go to previous messageGo to next message
Hi Tom,
I will make a try to your second suggestion.
Thanks for the tip,
St├ęphane
Re: Error when trying to inspect e4 apps with Scenic View [message #1837086 is a reply to message #1836743] Thu, 21 January 2021 20:23 Go to previous messageGo to next message
Hi Tom,
I made a try to your suggestion to run with ZuluFX "the quickest" option.
it solved the connection between ScenicView but I get theses exceptions in my e4 JavaFX app even if the application seems running normally:
I tried to pass some --add-opens or --add-exports without success.
Do you have an idea of the correct line to passe to make it run without such ugly exceptions please ?
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.eclipse.fx.osgi.fxloader.jpms.ModuleLayerWrapper$ControllerWrapper.addExports(ModuleLayerWrapper.java:173)
at org.eclipse.fx.osgi.fxloader.jpms.JavaModuleLayerModification.applyConfigurations(JavaModuleLayerModification.java:110)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.advancedModuleLayerBoostrap(FXClassLoader.java:483)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.initModuleLayer(FXClassLoader.java:426)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.getModuleLayer(FXClassLoader.java:293)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.findClassJavaFX11(FXClassLoader.java:207)
at org.eclipse.fx.osgi.fxloader.FXClassLoader.postFindClass(FXClassLoader.java:144)
at org.eclipse.osgi.internal.loader.BundleLoader.searchHooks(BundleLoader.java:530)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:493)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:425)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:398)
at java.desktop/com.sun.beans.finder.ClassFinder.findClass(ClassFinder.java:103)
at java.desktop/com.sun.beans.finder.InstanceFinder.instantiate(InstanceFinder.java:94)
at java.desktop/com.sun.beans.finder.InstanceFinder.find(InstanceFinder.java:66)
at java.desktop/com.sun.beans.finder.BeanInfoFinder.find(BeanInfoFinder.java:41)
at java.desktop/java.beans.Introspector.findExplicitBeanInfo(Introspector.java:484)
at java.desktop/java.beans.Introspector.<init>(Introspector.java:434)
at java.desktop/java.beans.Introspector.getBeanInfo(Introspector.java:205)
at org.apache.log4j.config.PropertySetter.introspect(PropertySetter.java:76)
at org.apache.log4j.config.PropertySetter.getPropertyDescriptor(PropertySetter.java:244)
at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.java:156)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:130)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:97)
at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:684)
at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:647)
at org.apache.log4j.PropertyConfigurator.configureRootCategory(PropertyConfigurator.java:544)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:440)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:334)
at org.apache.log4j.PropertyWatchdog.doOnChange(PropertyConfigurator.java:717)
at org.apache.log4j.helpers.FileWatchdog.checkAndConfigure(FileWatchdog.java:89)
at org.apache.log4j.helpers.FileWatchdog.<init>(FileWatchdog.java:58)
at org.apache.log4j.PropertyWatchdog.<init>(PropertyConfigurator.java:709)
at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:400)
at com.tus.core.runtime.log4j.Log4JConfigurator.configure(Log4JConfigurator.java:97)
at com.tus.core.runtime.log4j.Log4JConfigurator.configureFromClassPath(Log4JConfigurator.java:140)
at com.tus.core.runtime.initialiser.internal.Log4jInitialiser.initialise(Log4jInitialiser.java:34)
at com.tus.core.runtime.initialiser.InitialiserActivator.lambda$0(InitialiserActivator.java:23)
at com.tus.core.runtime.osgi.Service.lambda$2(Service.java:116)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.stream.SortedOps$SizedRefSortingSink.end(SortedOps.java:357)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:485)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at com.tus.core.runtime.osgi.Service.create(Service.java:189)
at com.tus.core.runtime.initialiser.InitialiserActivator.start(InitialiserActivator.java:23)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1015)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:603)
at org.eclipse.osgi.container.Module.start(Module.java:467)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1844)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1837)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1780)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1742)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1664)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.fx.osgi.fxloader.jpms.ModuleLayerWrapper$ControllerWrapper.addExports(ModuleLayerWrapper.java:170)
... 68 more
Caused by: java.lang.IllegalArgumentException: module javafx.base not in layer
at java.base/java.lang.ModuleLayer$Controller.ensureInLayer(ModuleLayer.java:216)
at java.base/java.lang.ModuleLayer$Controller.addExports(ModuleLayer.java:268)
... 73 more
Thomas Schindl wrote on Wed, 13 January 2021 10:40
Re: Error when trying to inspect e4 apps with Scenic View [message #1837409 is a reply to message #1837086] Fri, 29 January 2021 14:25 Go to previous messageGo to next message
Hm if you use ZuluFX why is the classloader hook still there? Are you using the SWT-Integration? BTW there https://github.com/eclipse-efx/efxclipse-rt/issues/412 since a long time filed against efxclipse
Re: Error when trying to inspect e4 apps with Scenic View [message #1837462 is a reply to message #1837409] Sat, 30 January 2021 17:28 Go to previous message
Hi Tom,
You were right, just removing -Dosgi.framework.extensions=org.eclipse.fx.osgi from JVM arguments did the trick :-)
Im' full JavaFX, no SWT-Integration
[Updated on: Sat, 30 January 2021 17:29]
Report message to a moderator
Previous Topic:M1+Q or M1+Z don't call respective handler
Next Topic:JavaFX documentation
Current Time: Tue Dec 06 08:31:54 GMT 2022
Powered by FUDForum. Page generated in 0.03239 seconds
