Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build failing with java 11.(Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-11 Host plug-in JavaSE_0.0.0 has not been found.)
PDE build failing with java 11. [message #1836338] Tue, 29 December 2020 15:01
ganesh rao is currently offline ganesh raoFriend
Hello All,
I am facing issue in running pde build with java 11
Getting below error:
I am using eclipse-SDK-4.10-win32-win32-x86_64 with pde version 3.10.200.v20181008-0641
I have tried work around adding p2.inf file mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=545653 but didn't work.
Log
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui.handlers_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui.part_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui.plugin_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui.progress_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.ui.services_0.0.0.
[java] [eclipse.buildScript] Host plug-in JavaSE_0.0.0 has not been found.
Previous Topic:AccessControlException in eclipse-based product when using New Plugin Project wizard
Next Topic:Is it possible to redirect to browser URL on splash image click?
Current Time: Sun Aug 14 22:53:59 GMT 2022
Powered by FUDForum. Page generated in 0.02274 seconds
