Re: Can't start IDE anymore - perhaps due to recent update? [message #1836161 is a reply to message #1836133] |
Tue, 22 December 2020 20:48 |
Stephen Rigel Messages: 5 Registered: December 2020 |
I think I'll adopt the practice of leaving my IDE un-updated in the future, as well. You gave me some things to try, thank you. Today I did a memory check, and found I was wrong when I said I'd went through all of Eclipse's files: I'd only looked in the program directory, but there are a lot of files within the project directory besides my particular project directories. Could there be a chance that there is some mega-data dump file Eclipse is trying to load on start?
With that in mind, I've come across running Eclipse from the command line with a '-clean' argument, which I tried without effect. There is also a '-clearPersistedState' argument suggested, which I have not tried. Does anyone recommend it or something else for this heap issue? Thank you.
Also, someone asked if the .ini file shared matched what I'm using now. I think so, but I've changed it so much I can't rightfully say. I'll post it again.
Attachment: eclipse.ini
(Size: 0.92KB, Downloaded 80 times)
FUDForum. Page generated in 0.03888 seconds
