Calling doGenerate in other doGenerate [message #1835954] |
Thu, 17 December 2020 08:04 |
Alexandra Tritean Messages: 37 Registered: March 2020 |
Member |
Is it viable to call doGenerate in other doGenerate method?
What I'm trying to achieve is the following flow: from .datamodel file -> generate . model file -> (from model file) -> generate .java files.
I have both generators working fine as standalone generators, but when queuing them I'm struggling with a NullPointerException and I'm not sure if I'm missing something in the configuration or the flow is not correct.
class DatamodelGenerator extends AbstractGenerator {
override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
// datamodel to model generation
var resourceURI = resource.URI
var modelFileName = resourceURI.toString.substring(resourceURI.toString.lastIndexOf('/')+1).replace("datamodel","model");
if(fsa.isFile(modelFileName)) {
var modelResourceURI = resourceURI.trimSegments(resourceURI.segments.size - 2).appendSegment("src").appendSegment("main").appendSegment("resources").appendSegment(modelFileName)
if(modelResourceURI.isPlatform){
var modelResource = resource.resourceSet.getResource(modelResourceURI, true)
var project = ResourcesPlugin.workspace.getRoot.getFile(new Path(modelResourceURI.toPlatformString(true))).project
var modelGenerationFsa = new EclipseResourceFileSystemAccess2
modelGenerationFsa.setProject(project)
modelGenerationFsa.setMonitor(new NullProgressMonitor())
modelGenerationFsa.setOutputConfigurations(outputConfigurationsMap)
new ModelGenerator().doGenerate(modelResource, modelGenerationFsa, new GeneratorContext)
What I saw while debugging is that after executing 1-2 lines from ModelGenerator, it randomly 'jumps' into GeneratorDelegate.afterGenerate with the generator being DatamodelDslGenerator. I suppose that I need some kind of synchronization/ executing ModelGenerator only after the DatamodelGenerator finished or something. I tried having the ModelGenerator.doGenerate call in the afterGenerate method of DatamodelGenerator, but that doesn't help either.
Am I doing something wrong? Is there another approach that I can follow in order to achieve the flow?
Thank you!
Kind Regards,
Alexandra
Re: Calling doGenerate in other doGenerate [message #1835955 is a reply to message #1835954] |
Thu, 17 December 2020 08:10 |
if you want two dsls to ping pong each other you need to
create a second custom written builder that touches the files
the first builder creates so that eclipse then calls the xtext builder on
the generates files again.
the approach you took could work too, but i dont see the problem with NPE as you did not post what is null.
Twitter : @chrdietrich
FUDForum. Page generated in 0.03699 seconds
