Home » Modeling » EMF » [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart
[CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835876] Tue, 15 December 2020 15:31 Go to next message
peugene Mising name is currently offline peugene Mising nameFriend
Member
I'm currently migrating CDO from 4.6 to 4.10.
On server restart a db exception occured :
Unique index or primary key violation: {0}; SQL statement:
INSERT INTO CDO_PACKAGE_UNITS (ID, ORIGINAL_TYPE, TIME_STAMP, PACKAGE_DATA) VALUES (?, ?, ?, ?) [23505-197]
In CDO 4.10, the server try to insert data in CDO_PACKAGE_UNITS twice. Then a primary key violation occured.
Between 4.6 and 4.10 the code change in org.eclipse.emf.cdo.internal.server.Repository#doActivate()
In 4.6 :
if (store.isFirstStart())
initSystemPackages(true);
initRootResource();
else
readPackageUnits();
initSystemPackages(false);
readRootResource();
In 4.10
initRootResource();
else
readPackageUnits();
readRootResource();
In 4.10 call to readPackageUnits(); is after initSystemPackages(false);
then in initSystemPackages(false);
packageRegistry is empty and the call to writePackageUnits occured twice.
In this second call, the aptemp to insert data in CDO_PACKAGE_UNITS failed.
Philippe
[Updated on: Tue, 15 December 2020 16:12]
Report message to a moderator
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835880 is a reply to message #1835876] Tue, 15 December 2020 17:08 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Philippe,
To be able to understand what's going on in your specific case I need to know a bit more about the actual data that's involved:
1) What package unit causes the primary key violation? You may have to use the debugger or enable tracing of SQL statements (org.eclipse.net4j.db/debug.sql = true)
2) What's in your CDO_PACKAGE_UNITS table? If you have the DB Browser enabled you can look at http://localhost:7777/tables?table=CDO_PACKAGE_UNITS
3) Do you use the <initialPackage .../> element in the cdo-server.xml? If so, what are the nsURIs?
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835903 is a reply to message #1835880] Wed, 16 December 2020 08:34 Go to previous messageGo to next message
Member
Hi Eike,
Thanks for reply.
I forgot an important information. I work with an EmbeddedServer like this : https://wiki.eclipse.org/CDO/Embedded whithout cdo-server.xml.
In my code I initialize the initial list of packages with nsURi like this :
http://fr.xxxxxx.xxxxxx/xxxxxxxx/xxxxxx/1.0.4/
I active tracing of sql statements and i post result here.
[Updated on: Wed, 16 December 2020 08:37]
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835906 is a reply to message #1835903] Wed, 16 December 2020 09:36 Go to previous messageGo to next message
Member
After the first start the content of the CDO_PACKAGE_UNITS table is :
http://fr.xxxxx.xxx/first/uri/1.0.4/
http://fr.xxxxx.xxx/xxxxx/xxxxx/execution/1.0.4/
http://fr.xxxxx.xxx/xxxxx/xxxxx/variant/1.0.4/
http://fr.xxxxx.xxx/xxxxx/xxxxx/variant/chain/1.0.4/
http://fr.xxxxx.xxx/xxxxx/xxxxx/variant/connection/1.0.4/
http://www.eclipse.org/emf/CDO/Eresource/4.0.0
http://www.eclipse.org/emf/CDO/Etypes/4.0.0
fr.xxxxx.xxx.connector.generic.connectionparameters.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.adapter.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.adapter.video.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.docker.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.exe.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.idl.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.lib.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.lib.csharp.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.lib.dll.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.lib.java.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.matlab.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.python.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.pythonlib.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.rcp.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.rcpservice.2.0.2
fr.xxxxx.xxx.connector.generic.connectionparameters.rcpvideo.2.0.2
http://fr.xxxxx.xxx/xxxxx/xxxxx/core/execution/1.0.0/
http://fr.xxxxx.xxx/xxxxx/xxxxx/search/1.0.0/
http://www.eclipse.org/emf/2002/Ecore
At the second start CDO try to insert the first URI again : http://fr.xxxxx.xxx/first/uri/1.0.4/
and then the DB exception occured.
At the restart in the doActivate() method the call of readPackageUnits() is after initSystemPackages(false);
Then packageRegistry is empty
if (initialPackages != null)
for (EPackage initialPackage : initialPackages)
if (!packageRegistry.containsKey(initialPackage.getNsURI()))
InternalCDOPackageUnit packageUnit = initPackage(timeStamp, initialPackage);
list.add(packageUnit);
In this code :
initialPackages != null : always true
!packageRegistry.containsKey(initialPackage.getNsURI() : always true
then the server try to insert CDO_PACKAGE_UNIT twice
[Updated on: Wed, 16 December 2020 09:37]
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835907 is a reply to message #1835906] Wed, 16 December 2020 09:48 Go to previous messageGo to next message
Member
I fix this issue in the embedded mode with returning null value for the initialPackages.
Does this mean that from CDO version 4.10 we should no longer use initialPackages in the configuration of the CDO server?
[Updated on: Wed, 16 December 2020 10:09]
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835908 is a reply to message #1835907] Wed, 16 December 2020 10:15 Go to previous messageGo to next message
Member
The problem if I don't initialize the packages, the tables of my models are not created.
I should have over 300 tables, CDO only created 30.
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835911 is a reply to message #1835908] Wed, 16 December 2020 10:31 Go to previous messageGo to next message
Member
The problem is the same with or withour initializePackages all tables are not created. This is not the same problem, i open a second topic.
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835924 is a reply to message #1835911] Wed, 16 December 2020 15:28 Go to previous messageGo to next message
I can reproduce your original problem. It's a bug in CDO which is related to the use of IRepository.setInitialPackages(). Can you please open a bugzilla, so that we can track the problem and the fix?
In fact you can work around the problem by not specifying any initial packages. New/missing packages are always created on demand during normal commits. The setInitialPackages() method is mostly required when the repository is replicated (e.g., an OfflineClone or BackupRepository), because EPackages don't participate in the replication mechanism.
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835927 is a reply to message #1835924] Wed, 16 December 2020 15:41 Go to previous messageGo to next message
Member
Thanks Eike,
I open an Bugzilla.
Yes, i fixed the issue by not specify initialPackages
Re: [CDO] - Migrating from 4.6 to 4.10 - DB Exception on server restart [message #1835965 is a reply to message #1835927] Thu, 17 December 2020 09:59 Go to previous message
Member
Issue submitted : https://bugs.eclipse.org/bugs/show_bug.cgi?id=569775
Previous Topic:Mint tool, where can I find it?
Next Topic:[SOLVED][CDO] - Migrating from 4.6 to 4.10 - IllegalStateException type mapping EFeatureMapEntry
Current Time: Tue May 11 05:13:51 GMT 2021
Powered by FUDForum. Page generated in 0.02420 seconds
