Home » Newcomers » Newcomers » Cannot install any plugin(I can't install any plugin in Eclipse even after I have uninstalled Eclipse several times.)
Cannot install any plugin [message #1835561] Sun, 06 December 2020 20:55 Go to next message
This is the error message I am getting: Please help
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.xtend.core,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.doc,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.examples,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.ide,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.ide.common,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.lib,2.24.0.v20201130-0911.
Artifact not found: osgi.bundle,org.eclipse.xtend.lib.macro,2.24.0.v20201130-0911.
Artifact not found: osgi.bundle,org.eclipse.xtend.m2e,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtend.standalone,2.24.0.v20201130-0959.
Artifact not found: osgi.bundle,org.eclipse.xtext,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.activities,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.builder,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.builder.standalone,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.buildship,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.edit,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.shared,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.shared.jdt38,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.common.types.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.doc,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ecore,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.generator,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.ide,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.java,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.junit4,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.logging,1.2.15.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.m2e,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase.ide,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.purexbase.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.smap,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.testing,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codemining,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates.ide,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.codetemplates.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.ecore,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.shared,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.ui.testing,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.util,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ide,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.junit,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.lib,2.24.0.v20201130-0911.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.testing,2.24.0.v20201130-0919.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xbase.ui.testing,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.generator,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ide,2.24.0.v20201130-0914.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui.examples,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.ui.graph,2.24.0.v20201130-0931.
Artifact not found: osgi.bundle,org.eclipse.xtext.xtext.wizard,2.24.0.v20201130-0914.
Re: Cannot install any plugin [message #1835622 is a reply to message #1835561] Tue, 08 December 2020 20:49 Go to previous messageGo to next message
I think this needs a lot more detail to try and figure it out. For instance, how are you trying to install plug-ins, what are you trying to install,
and what are you starting from? Basically, how would someone reproduce this in an effort to help? And is it all plug-ins that fail to install
with this kind of message, or just whatever this is?
Re: Cannot install any plugin [message #1835692 is a reply to message #1835561] Thu, 10 December 2020 09:35 Go to previous messageGo to next message
Tell me please how the plugins are being installed?
As for me, the problem is related to the corporate proxy.
Try to update the local site.
Re: Cannot install any plugin [message #1835733 is a reply to message #1835692] Fri, 11 December 2020 00:32 Go to previous messageGo to next message
Hey guys. What I did was, I manually downloaded the plugin and then uploaded it to Eclipse and then went to the marketplace and updated the plugin. It worked after that. Thanks for your reply.
Re: Cannot install any plugin [message #1835734 is a reply to message #1835622] Fri, 11 December 2020 00:32 Go to previous messageGo to next message
Hey Nithin. What I did was, I manually downloaded the plugin and then uploaded it to Eclipse and then went to the marketplace and updated the plugin. It worked after that. Thanks for your reply.
Re: Cannot install any plugin [message #1835735 is a reply to message #1835692] Fri, 11 December 2020 00:33 Go to previous message
Hey Dalila. What I did was, I manually downloaded the plugin and then uploaded it to Eclipse and then went to the marketplace and updated the plugin. It worked after that. Thanks for your reply.
Previous Topic:Exception in thread "main" java.lang.Error: Unresolved compilation problem:
Next Topic:I have a problem with the intellisense screen and I can't localize solution
Current Time: Sun Nov 02 12:39:02 EST 2025
Powered by FUDForum. Page generated in 0.09948 seconds
