Home » Modeling » TMF (Xtext) » New Xtext project from ECore - Packaging error("Could not resolve ECLassifier" for double inheritance)
New Xtext project from ECore - Packaging error [message #1835536] Sun, 06 December 2020 11:03 Go to next message
Edouard R. Batot is currently offline Edouard R. BatotFriend
Hi everyone,
I am trying to generate a Xtext from an Ecore metamodel.
The metamodel seems alright; containments checked, nsURI and prefixes set.
Now, when I start a "New Xtext project from an existing Ecore model", I get errors on a bunch of classes. The classes in question are all leafs of a same branch.
Here's what happen:
[There was here a clear descrption of the problem. I remove it for PI]
Is it something about parameterization I am missing ? Or what ? I am at a loss, thank to anybody who can give me a hint on how to get these errors out.
Ed
[Updated on: Mon, 07 December 2020 08:01]
Report message to a moderator
Re: New Xtext project from ECore - Packaging error [message #1835537 is a reply to message #1835536] Sun, 06 December 2020 11:05 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
make sure you emf project has Xtext nature (rightclick, configure, Convert to Xtext project)
and that it is added to the yourdsl project as dependency.
if that one does not help: please create and share a minimal reproducible example
Twitter : @chrdietrich
[Updated on: Sun, 06 December 2020 11:06]
Re: New Xtext project from ECore - Packaging error [message #1835538 is a reply to message #1835537] Sun, 06 December 2020 11:10 Go to previous messageGo to next message
Ouch, your answer came before I had time to resize the image !!!
Thanks so much.
Questions below:
It is.
How do I check that ?
I can past Xtext example and show it works ;)
More seriously, I'll work on that but it aint easy to do... A small version of that same Ecore worked perfectly. When I had thos inheritance leaves, the thing explodes.
Re: New Xtext project from ECore - Packaging error [message #1835539 is a reply to message #1835538] Sun, 06 December 2020 11:13 Go to previous messageGo to next message
yes. but to be able to understand and debug it, i need something that i can debug locally
Re: New Xtext project from ECore - Packaging error [message #1835567 is a reply to message #1835539] Mon, 07 December 2020 08:02 Go to previous messageGo to next message
Too quick maybe, too quick..
Re: New Xtext project from ECore - Packaging error [Solved] [message #1835652 is a reply to message #1835567] Wed, 09 December 2020 13:52 Go to previous messageGo to next message
The solution to this issue was to use "platform" imports:
i
import "platform:/path/to/yourdsl.ecore"
import "platform:/path/to/yourdsl.ecore#//package1" as package1
import "platform:/path/to/yourdsl.ecore#//package2" as package2
instead of URIs:
import "http://yourdsl.ecore"
import "http://yourdsl.ecore#//package1" as package1
import "http://yourdsl.ecore#//package2" as package2
There are some warnings, but once the plugin is on, it's all fine.
Asking for a repro is often a lazy answer.
Re: New Xtext project from ECore - Packaging error [Solved] [message #1835658 is a reply to message #1835652] Wed, 09 December 2020 15:16 Go to previous message
your namespaces look wired.
maybe that is the problem
maybe its also a problem with nested packages
Previous Topic:How to cleanly handle runtime exceptions in AbstractModelInferrer
Next Topic:Adding a new resource to the IResourceDescriptions
Current Time: Tue Sep 26 23:18:56 GMT 2023
Powered by FUDForum. Page generated in 0.02550 seconds
