Home » Newcomers » Newcomers » Errors Occurring due to spring-orm file(Errors Occurring due to spring-orm file: C:/Buildworkspace/m2repo/org/springframework/spring-orm/4.3.5.RELEASE/spring-orm-4.3.5.RELEASE.jar)
Errors Occurring due to spring-orm file [message #1835450] Thu, 03 December 2020 15:43 Go to next message
Frank Guarascio is currently offline Frank GuarascioFriend
Error occuring:
Archive for required library: 'C:/Buildworkspace/m2repo/org/springframework/spring-orm/4.3.5.RELEASE/spring-orm-4.3.5.RELEASE.jar' in project 'borrower-services-vtl' cannot be read or is not a valid ZIP file
The project cannot be built until build path errors are resolved.
This file reads as corrupt when I click on it but it may be just an inexecutable jar.
When I remove it the junit test won't execute due to it causing other problems with java.lang.NoClassDefFoundError:org.springframework.context.support
Re: Errors Occurring due to spring-orm file [message #1835454 is a reply to message #1835450] Thu, 03 December 2020 17:02 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Try redownloading that jar file. If it's unreadable, it's not something you can just work around.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Errors Occurring due to spring-orm file [message #1835468 is a reply to message #1835454] Thu, 03 December 2020 21:26 Go to previous messageGo to next message
Thank you - I deleted the contents of the whole springframework folder and when I restarted Eclipse it was repopulated.
There were further problems posed by a corrupt m2repo folder. I again deleted the contents of the folder and again it was repopulated upon restart.
Re: Errors Occurring due to spring-orm file [message #1835547 is a reply to message #1835468] Sun, 06 December 2020 16:40 Go to previous messageGo to next message
...and things are working now?
_
Nitin Dahyabhai
Re: Errors Occurring due to spring-orm file [message #1835557 is a reply to message #1835547] Sun, 06 December 2020 20:40 Go to previous message
Yes - thanks so much!
Previous Topic:display problems on Big Sur
Next Topic:crash caused by insufficient cache
Current Time: Tue Apr 16 16:12:24 GMT 2024
Powered by FUDForum. Page generated in 0.52803 seconds
