Home » Newcomers » Newcomers » Rational Application Developer (RAD 8.5.5) stops working after upgrading to macOS Big Sur
Rational Application Developer (RAD 8.5.5) stops working after upgrading to macOS Big Sur [message #1835373] Tue, 01 December 2020 20:54 Go to next message
Poorna Thanneeru is currently offline Poorna ThanneeruFriend
I have upgraded to Big Sur. Since then, RAD (which is built on Eclipse) opens up, but I cannot click anything on it. The User Interface is disabled. How can I fix this problem? Thanks for input.
[Updated on: Tue, 01 December 2020 20:56]
Report message to a moderator
Re: Rational Application Developer (RAD 8.5.5) stops working after upgrading to macOS Big Sur [message #1835376 is a reply to message #1835373] Wed, 02 December 2020 01:29 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You should go through product support, but for starters I'm pretty sure that version is several years old and you should try what ever is the current release.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Rational Application Developer (RAD 8.5.5) stops working after upgrading to macOS Big Sur [message #1835404 is a reply to message #1835376] Wed, 02 December 2020 14:27 Go to previous messageGo to next message
Thanks. You mean go with Eclipse support or RAD support? I need to wait to go to latest version of RAD. But, I am not sure what version of Eclipse does latest RAD (9.7x) uses.
Just did some research and found that latest version of RAD (9.7x) is supported on macOS High Sierra and it uses Eclipse Oxygen workbench. So, not sure if it will work on Big Sur.
[Updated on: Wed, 02 December 2020 15:04]
Re: Rational Application Developer (RAD 8.5.5) stops working after upgrading to macOS Big Sur [message #1835427 is a reply to message #1835404] Thu, 03 December 2020 08:18 Go to previous message
I mean RAD support.
Nitin Dahyabhai
Previous Topic:Unable to see the option to create new Javascript project
Next Topic:Java Virtual Machine Launcher
Current Time: Thu Jun 17 22:00:26 GMT 2021
Powered by FUDForum. Page generated in 0.04138 seconds
