Home » Modeling » TMF (Xtext) » Redundant usage of =current
Redundant usage of =current [message #1835352] Tue, 01 December 2020 12:18 Go to next message
The Xtext grammar contains
AssignableAlternatives returns AbstractElement:
    AssignableTerminal ({Alternatives.elements+=current} ('|' elements+=AssignableTerminal)+)?
Is there any advantage to this obscure non-EBNF-like form compared to the regular
    AssignableTerminal
|   {Alternatives} elements+=AssignableTerminal ('|' elements+=AssignableTerminal)+
More generally is there any example of
... X ... {Y.f=current ...)? ...
that cannot be more readably rewritten as
... X ...  ...
| {Y} ... ... f=X ... ...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=565093#c3 files this as an Xtext enhancement.
Ed Willink
Re: Redundant usage of =current [message #1835353 is a reply to message #1835352] Tue, 01 December 2020 12:29 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
as the
rewrites the ast/tree and
does not, they do not do the same.
e.g. for mathematical expressions
https://www.eclipse.org/Xtext/documentation/307_special_languages.html#expressions
the rewrite will give you proper trees that care about precedences
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Redundant usage of =current [message #1835368 is a reply to message #1835353] Tue, 01 December 2020 19:44 Go to previous messageGo to next message
Yes, but it only rewrites because it was parsed wrongly. By not using current, the correct AST is parsed directly. In both cases the net result is a single AssignableTerminal else an Alternatives with two or more AssignableTerminal elements .
Ed Willink
Re: Redundant usage of =current [message #1835389 is a reply to message #1835368] Wed, 02 December 2020 09:08 Go to previous message
As pointed out by Sebastian on https://bugs.eclipse.org/bugs/show_bug.cgi?id=565093 , the real reason is that the rewrite is left-recursive and Xtext/ANTLR does not support left recursion. current= is an effective trick. It would be nice if it was hidden.
Ed Willink
Previous Topic:Define a limited string consisting out of figures/digits only
Next Topic:Join two scopes
Current Time: Sat Sep 25 13:49:11 GMT 2021
Powered by FUDForum. Page generated in 0.02131 seconds
