PHP generics support in Eclipse [message #1834958] |
Sun, 22 November 2020 07:22  |
I was looking for a sort of generics support (as for example known in Java world) for one of my PHP projects. I found medium.com/@ondrejmirtes/generics-in-php-using-phpdocs-14e7301953 (Sorry I am not allowed to link here yet) where in phpstorm it seems this is supported.
As this is only related to phpdoc, it is merely a thing of the IDE. Thus my question: Is there some support for something similar in Eclipse PDT or is there a plan for that?
If no: Where can I file a feature request? The Eclipse bug tracker does not allow to add a new "bug" and I am unsure if under github the issues are worked on.
Thank you
Christian
Re: PHP generics support in Eclipse [message #1837777 is a reply to message #1834958] |
Sat, 06 February 2021 02:11   |
I'm currently evaluating eclipse after using textmate for all my development for many years. what i miss in eclipse and what I can't find any solution for are some kind of generic templates:
I'm using PDT for my JavaScript and PHP development, and it supports code-templates. however , in my projects I'm writing large amounts of shell-scripts, yml-configuration-files, xml-files, gnu make scripts, etc., too. I'm writing source-documentation for all these scripts using a generic syntax (similar to robodoc) and you can save much time, when you can insert the doc-blocks using templates. however, besides PDT not all of the editor-plugins support templates.
Is there some generic way of storing code-snippets/templates in eclipse, which will work across all editor-plugins? I think it should be possible to implement such using eclipse monkey -- however, it seems development of monkey was stopped?
I'm using Eclipse 3.4.0.
FUDForum. Page generated in 0.22796 seconds
