Home » Modeling » TMF (Xtext) » TemplateProposalProvider for webapplication(Possible to provide templates in the Xtext web editor ?)
TemplateProposalProvider for webapplication [message #1834752] Tue, 17 November 2020 12:13 Go to next message
Michiel Jonckheere is currently offline Michiel JonckheereFriend
I am currently trying to use Xtext to create a structured editor. The reason that I chose Xtext is that it has also a web editor.
I have been experimenting with it, and one of the main features that it should have is the auto-completion, by using some templates. I was able to create templates that can be used in the eclipse application, but these don't work in the web editor. The templates are located in `<package>.ui/templates/templates.xml`.
I also found another way to create the templates, which is used in the statemachine web example (https://github.com/eclipse/xtext-web/tree/8edb0503934e7e649317097de8558cdfa9ec9102). In the ide/src folder, they have a class which extends the AbstractIdeTemplateProposalProvider. I have tried to create the same classes as they have done (a TemplateProposalProvider and a ContentProposalProvider) and in the IdeModule.java class, I added the bindIdeContentProposalProvider method. When I build the web editor again, it wouldn't load properly (no editor, only the title is visible) and in the eclipse editor the new template I made was not available.
In the attachments I added some screenshots of the code I currently have.
Does someone know how I should use the AbstractIdeTemplateProposalProvider properly so it will work in the web editor? I can not find a tutorial that makes use of it... Or is there another possible way to provide auto-compete templates in the web editor?
Thanks in advance for your response.
Re: TemplateProposalProvider for webapplication [message #1834772 is a reply to message #1834752] Tue, 17 November 2020 16:16 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
hi, this (cursor and co) is an orion only feature
and yes you have to subclass and bind AbstractIdeTemplateProposalProvider
and delegate as StatemachineWebContentProposalProvider does
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Tue, 17 November 2020 16:20]
Report message to a moderator
Previous Topic:Can Ecore::EString be used in XText?
Next Topic:Disabling inter-file Cross referencing
Current Time: Mon Jun 14 08:12:27 GMT 2021
Powered by FUDForum. Page generated in 0.02014 seconds
