Home » Modeling » Papyrus » Difference between PrimitiveType and <EPackage,ModelLibrary > EDataType
Difference between PrimitiveType and <EPackage,ModelLibrary > EDataType [message #1834663] Sun, 15 November 2020 00:30 Go to next message
John Doe is currently offline John DoeFriend
Member
So I am creating a UML profile with Papyrus and I was advised to use PrimitiveType from the Palette.
Let's say I have a property "phone_number", which will be an integer. What is the difference if I create a PrimitiveType and name it INT and on Properties -> Type -> MyPackageName -> INT,
or if I select it from the Properties -> Type -> <EPackage,ModelLibrary > PrimitiveTypes ->. EDataType Integer.
My end goal is to generate an Xtext grammar for this UML profile. What would be some benefits of each approach?
Thank you!
Re: Difference between PrimitiveType and <EPackage,ModelLibrary > EDataType [message #1834668 is a reply to message #1834663] Sun, 15 November 2020 12:05 Go to previous messageGo to next message
It depends whether you want tooling to understand the semantics of "INT" such as may-be-zero, can-be-added, cannot divide-by-zero ....
By default you have nothing, not even a defined storage. If you map the Ecore implementation to java.lang.int you get some functionality.
Tools know about the Integer, they know nothing of INT. To remedy this Eclipse OCL provides the OCLforUML profile so that you can apply an Integer/Real/... stereotype to your novelty.
You can also define your own PrimitiveType named Integer. Whether this is or is not the same type as a built-in PrimitiveType named Integer is unclear. Eclipse OCL clarifies by specifying that the package hierarchy of Primitive/Tuple/Collection/Map/Lambda types is to be ignored when determining a singleton type for each such potential ambiguity.
Ed Willink
Re: Difference between PrimitiveType and <EPackage,ModelLibrary > EDataType [message #1834672 is a reply to message #1834668] Sun, 15 November 2020 12:57 Go to previous message
See https://www.eclipse.org/forums/index.php/m/1834670/#msg_1834670 on Xtext newsgroup.
Ed Willink
Previous Topic:Association or property type in UML Profile?
Next Topic:Problems encountered in the model
Current Time: Wed Mar 03 15:59:21 GMT 2021
Powered by FUDForum. Page generated in 0.02123 seconds
