Re: Eclipse 2020-09 (for Java) XML Editor shows new errors which were not there before. What to do? [message #1834541 is a reply to message #1834529] |
Thu, 12 November 2020 07:14 |
master master Messages: 5 Registered: November 2020 |
Ed Willink wrote on Wed, 11 November 2020 20:00Hi
If I'm using an XML editor, I expect to be told about rubbish XML by default. Perhaps an editing option facilitates various dimensions of rubbish.
If I want to edit rubbish XML, I use NotePad / a Text editor.
Ed Willink
Hellow!
Notepad does not highlight XML syntax or show XML structure errors, so I consider your advice to be useless!
Arbitrary fields with correct syntax in XML are not a bug, this is normal and was fine until the last Eclipse update. As I wrote above, even "Validate" does not see an error here, this "error" is shown only by the XML editor. If "Validate" showed an error, then it would be another matter, but this is a bug.
I ask you to tell me how I can remove this error, maybe I can change something in the configuration of the Eclipse itself or the Xml editor?
FUDForum. Page generated in 0.04331 seconds
