Home » Modeling » Compare » equalityHelperExtensionProvider extension point ignored
equalityHelperExtensionProvider extension point ignored [message #1834473] Tue, 10 November 2020 23:50 Go to next message
Ernesto Posse is currently offline Ernesto PosseFriend
Hi. I'm trying to override the Default EqualityHelper, so I attempted to use the equalityHelperExtensionProvider extension point in org.eclipse.emf.compare.rcp but the class I defined associated with this extension point never gets used. in spiute of the fact that I gave it a very high ranking. I'm using the DefaultMatchEngine. Is this a bug or is there another way to override the EqualityHelper?
I looked at the solution described in https://www.eclipse.org/emf/compare/documentation/latest/FAQ.html which creates a new MatchEngine with a new ComparisonFactory, but the problem is that the last line is
Comparison comparison = EMFCompare.builder().setMatchEngine(new DefaultMatchEngine(DefaultMatchEngine
		.createDefaultEObjectMatcher(UseIdentifiers.WHEN_AVAILABLE), comparisonFactory)).build().compare(scope);
which means that you have to call the compare method yourself, but I need a solution which uses the existing UI actions already integrated with EGit, which call the compare method.
In short, is there a way to override the EqualityHelper that doesn't require me to create my own new UI actions or EGit integration?
PS: I'm using EMF Compare 3.3.7 on Papyrus 4.4 2019-06.
Re: equalityHelperExtensionProvider extension point ignored [message #1834695 is a reply to message #1834473] Mon, 16 November 2020 10:02 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
The equalityHelperExtensionProvider is not meant for use to replace the equality helper, but to add new kind of mapping rules to it. There are currently no extension point to completely replace the equality helper, but you could go the long way and replace the match engine by your own (org.eclipse.emf.compare.rcp.matchEngine extension point). You can simply provide your own MatchEngine.Factory with a higher ranking than the default and change the equality helper we're using to create it. Overriding org.eclipse.emf.compare.match.impl.MatchEngineFactoryImpl and changing the org.eclipse.emf.compare.match.impl.MatchEngineFactoryImpl.getMatchEngine() implementation should get you the expected result.
Laurent Goubet
Obeo
Re: equalityHelperExtensionProvider extension point ignored [SOLVED] [message #1834707 is a reply to message #1834695] Mon, 16 November 2020 16:05 Go to previous message
Thanks Laurent.
Indeed, overriding the MatchEngineFactory does work.
My solution is as follows:
public class MyMatchEngineFactory extends MatchEngineFactoryImpl {
    public MyMatchEngineFactory() {
        super(DefaultMatchEngine.createDefaultEObjectMatcher(UseIdentifiers.WHEN_AVAILABLE),
                makeComparisonFactory());
    private static IComparisonFactory makeComparisonFactory() {
        return new DefaultComparisonFactory(makeEqualityHelper());
    private static IEqualityHelperFactory makeEqualityHelper() {
        return new DefaultEqualityHelperFactory() {
            public IEqualityHelper createEqualityHelper() {
                final LoadingCache<EObject, URI> cache = EqualityHelper.createDefaultCache(getCacheBuilder());
                return new EqualityHelper(cache) {
                    public boolean matchingValues(Object object1, Object object2) {
                        // My custom code
                        return match;
and in the corresponding plugin.xml:
   <extension
         point="org.eclipse.emf.compare.rcp.matchEngine">
      <engineFactory
            class="my.plugin.MyMatchEngineFactory"
            label="My Match Engine"
            ranking="20">
      </engineFactory>
PS: It would be nice to have a simpler way to override the EqualityHelper.
Previous Topic:Maven for EMF Compare
Next Topic:Crossover operation by EMF Compare
Current Time: Sat Dec 07 08:47:55 GMT 2024
Powered by FUDForum. Page generated in 0.03941 seconds
